First ever Garage Sale...
The Rider
Plainfield, IL
... and I spotted a matching pair of KRA's at the end of the driveway. Looks like the - sadly deceased - previous owner was something of a Harley fan.
Anyway, following a short negotiation, an exchange of $75 & a trip in the Land Rover later, they were in their new home and awaiting some TLC. Should keep me out of trouble for the next few weeks...
There is some surface rust but no holes, bangs, dents or major damage and everything is flat, square & true.
However, the bottom drawer of the top box has a broken slide. See pictures. The drawer still slides in & out but on the broken side it moves along the floor of the box instead of the runner.
Any suggestions on how this could be repaired / replaced would be much appreciated.:headscrat
Also, I initially thought the rolling cab was missing the lower drawers, but I have seen a couple of these posted recently and they all have that curious open space at the bottom. Were these drawers optional extras?
Thanks in advance for your input!
Broken drawer slide - Ouch! Any idea how this can be repaired??
T
The Rider
Plainfield, IL
This was your FIRST-EVER Garage Sale? Man, talk about beginner's luck!
Nice score.
Correct! First ever!! I could scarcely believe my good luck! Right place at the right I suppose.
I also bagged a whole load of tools which I'll post in a separate thread when I've had time to upload the pictures.
Lump
Jamestown, Ohio
Ha. Just wait till you see what happens next, if your luck is typical at this point...
For example, first time I went deer hunting I took a giant buck with huge 10-point rack in the first full hour of my first morning of my first deer hunt ever. That was about 10 years ago, and I've taken several deer since then, but never even SEEN anything like that one ever again. Chuckle.
Packard V8
Spokane, WA
Yep, I've got that same set and the bottom space was standard, extra drawers were available extra cost option. Does yours have the three small drawers across the top?
As for repairing your broken drawer slide groove, I know a guy who's really good with a TIG welder and once I got mine dinged back, I made a false slide out of a piece of plastic to clamp the loose end in place and spaced just right. He tack-welded the slide in place. We then cut a piece of 1/8" steel as long as the broken part of the slide. He welded that to the drawer side and to the slide as reinforcement.
As to a full restoration - your boxes, your time and your money. However, never again, not for me, no way, no how. I've done cars which took less time, effort and money than a top and bottom box. No way will you add as much value as you add cost. I vote for WD40, sandpaper and steel wool. The patina works for me.
jack vines
mooman
CHICAGO, IL
Good score!
There is a similar bottom box in the classifieds for $150 that looks a little worse than yours.
T
The Rider
Plainfield, IL
jack vines
Thanks for the insight Jack!
Yes the base cabinet does have the three small drawers across the top.
The slide repair sounds quite involved. I'm no welder, but I know somebody close by that restores & repairs antique Triumph motorcycles. I'll run it by him and see if he can steer me in the right direction.
I hear you on the resto vs patina thing and if I'm being honest I'm still on the fence.
But I was looking for a project piece, so I'll rub out the rust as best I can and then make a decision from there.
JASTECH
Gering, NE
Yes, nice indeed! I should be living where they have flea markets and bunches of yard sales. You guys are lucky. Please keep me in mind for a bigger set. I have 27"W set.
Thanks, JASTECH
Grigg
Lexington, VA
...However, the bottom drawer of the top box has a broken slide...
I have a box with a similarly worn out drawer slide.
Talked to my Snap-On guy a couple weeks ago and he said no problem to get the removable slide parts, and with the box model number he's pretty sure he can get the replacement part that is spot welded to the case or drawer.
Been trying to catch up with him for almost three weeks now, hopefully this Friday I'll have an answer weather he can get the parts or not.
If so I'll remove the old and TIG plug weld the new in it's place.
Grigg
T
The Rider
Plainfield, IL
Grigg
Interesting. Would you mind updating and letting me know how it turns out as well as how much it costs.
Thank you!
Grigg
Lexington, VA
Thank you!
Just got off the truck, my dealer had the replacement drawer slides in stock and exchanged my old ones.
Looked in the catalog to find the part numbers for the fixed part of the slide, and the number is still good but none shown in stock at the warehouse.
He sees no problems getting them, but only time will tell if it actually happens.
I'll let you know, but you might as well take your tool box number to your dealer and order what you need.
Grigg
T
The Rider
Plainfield, IL
I'm in the throes of sanding off my KRA300E bottom box pictured in the initial post. Drawers and slides have all been removed but I have a couple of questions:
1. How do I remove the Snap On emblem?
The aluminium roller louvres do not allow access to the rear of it. Do I just pry it off?
2. How do I remove the side pull handle? (see picture below)
Again, there is no access from inside the box to the outer steel wall the handle is attached to.
3. What is the purpose of the small access plate on the left hand side of the box (again see picture below)?
I have removed the four corners screws, taken off the plate and peered around inside but it doesn't appear to have any function that I can discern!
crewchief888
NW indiana
gently pry it off
remove the rubber end pieces, slide the outer 1/2 of the handle off, )friction fit)remove the 4 screws that go through the inner handle 1/2, the spacers, and screw into the box inserts
:dunno: i have one of these boxes at the shop, i never noticed an access plate on it
:beer: :spit:
billymade
New Mexico
I have one in my Snapon box; AFIK, they used to sell a pig tail eletrical cord setup, that had electrical outlet plugs on them.... that way you had protable outlets for your toolbox!
Rickster
SE PA
I had one of those bottom boxes for a while. On mine that door pull went all the way to the top and there were three smller drawers across the top row.
T
The Rider
Plainfield, IL
crewchief - thanks for the info. Teasing apart that bent & rusty handle looks like being a project all in itself...!:shocking:
billymade - electrical outlet would make sense.
rickster - mine also has the three small drawers along the top.
:beer:
T
The Rider
Plainfield, IL
Well thanks to crewchief888 & a little gentle persuasion removing the handle turned out to be a piece of cake.
Ends caps removed & outer portion half way off:
Handle outer completely off & sitting on top of the box:
And here's how the box sits now; drawers & slides removed...
...wheels scrubbed clean, & caster hardware soaking in vinegar.
Next step is sanding & paint prep.
