I'm trying to fish some mini split lineset up a finished wall from the floor below. The floor below is wide open. I've got a 2 3/4" hole drill thru the bottom plate, but when looking thru the hole, I see I put some blocking b/w the studs in the finished space.
I think I can making a hole saw extension by MIG welding a threaded rod to a hole saw extension bit (I've already hacked this extension for a previous job - see pic).
If a lay the extension (7/16" diameter) and the threaded rod (1/2") on a piece of angle iron they should line up straight. I'll strip the zinc coating off the rod with muriatic acid.
IS this going to work or am I spinning my wheels?
