cj8lvr
I'm building a 2,220 sq ft Miracle Truss building in my back yard.
This is a steel truss building with wooden purlins and girts covered entirely in sheetmetal exterior.
My intention is to have it sprayed with 2" closed cell foam after I have it up.
In talking with a local metal building supplier (Summertown Metals) about some extra trim that I'll need for windows not in the plans at the time I ordered from Miracle Truss..... they (Summertown) asked if I planned to insulate it. I told them yes and they recommended a product that they carry that would go between the lumber and the exterior sheet metal. It's called "Therma Guard" and is made by Dutch Tech. It's *NOT* bubble wrap but the installation of it is essentially the same thing. It's different in that it has reflective foil on the top side (pointing towards the bottom of my sheet metal, and a tough polypropylene bottom layer. Overall about 3mm thick.
Some questions:
1) Does anybody here have any first-hand experience with this product or something very similar?
2) Do you think this will create any moisture issues anywhere in the equation?
3) What do you do if for some reason I need to put a new sheet metal roof on this building and the inside is sprayed with foam and this layer isn't in between the metal and foam?
4) Do you think it's worth the ~$1,400 or more to wrap it, roof and walls before installing my sheet metal.
I'm in Alabama so consider stupid humidity levels all the time, including winter months.
Here's my build thread on my shop:
https://www.garagejournal.com/forum/threads/cartotracks-miracle-truss-garage-36x50-fab-room.493983/
Product website:
https://www.dutchtechindustries.com/therma-guard/
Here's a pic of the product being installed from the Dutch Tech website:
Some questions:
Product website:
