Have a bunch of shovels, pick axes, weed wackers.
Want to get then off the ground, but easy to access when needed.
I don’t have walls in my shed, so maybe a track system?
Many of the people around here do that. Just leave them out in the wet dirt to rust and watch the wooden handles develop killer splinters. Throw them away after a while and buy new ones.I like to strew them about the place.
Sort of the same. I keep mine in a large plastic garbage can. I’m often tempted to drag it to the curb on garbage dayI cut the top out of 55-gallon plastic drum and drop them in the there.
.....NOT IN THE GARAGE WERE THE PARKED CAR ARE!!!!!
No, no, no...I have a Rubbermaid double door closet (by outside man door) and inside I built a skeleton wood frame to hang more than the 50 lbs they tell you is the maximum to hang from the sides. So, I store all the gardening stuff that can "ding" the cars in there....
gemplers.com
I basically did the same thing using longer 2×3 nailed to the board so I can hang multiple things per slot.I drill a 2x6 at 12" intervals and put in 6" long dowels, angled upward about 15 degrees.
gemplers.com
ah that one is nice as it mounts on a studUse a lot of these both at work and home:
Gemplers Double Prong Stud Mount Tool Rack
Organize tools with Gemplers stud mount tool storage rack. Great for unfinished garages and shops.gemplers.com
They have one that surface mount as well.ah that one is nice as it mounts on a stud
Hard to hang a 12lb sledge hammer on pegboard.Doesn't anybody use pegboard anymore? I attached a 4x8 sheet to my studs and with various hooks I hang pretty much everything and can switch it around easily should the need arise.
Can you grab a pic of the inside sometime.....NOT IN THE GARAGE WERE THE PARKED CAR ARE!!!!!
Post #13 above, a section at front corner and short wallDoesn't anybody use pegboard anymore? I attached a 4x8 sheet to my studs and with various hooks I hang pretty much everything and can switch it around easily should the need arise.
I used the exact hangers you pictured first. I think I got them on Amazon. I just put up a 2x3 or 2x4 (I don't remember and it's raining so I'm not going out to the shed now). I spaced the hangers evenly and that was it. Some rakes have the forks facing up, some down. I've also used some stout nails angled upward into the same 2x3 for some added tools that had a hole in the handle after the fact.I started by measuring the back wall of my shed. Taped out a matching rectangle on the driveway. Then got all of the yard shovels & rakes & implements of destruction out, and laid them out and moved them around until they all fit in the rectangle. I put a couple of 2x4 across to provide a place to mount hangers.
Most of the tools got this kind of hanger
some things got two prong hooks like these
The end goal was getting everything hung on the wall, out of the way, out of the garage, out of the elements, but easily accessible. The “accessible” part isn’t as true in the winter, as I have more stuff in the shed (ugly drum smoker, Weber grill, patio furniture), but I don’t need much “garden tools” in the winter.
The down side to this fixed organization is that it makes adding a new tool difficult. Something more easily rearranged may be better if you expect to add tools. I figured that after 30+ years here, I wasn’t adding any new yard tools so this would be ok. Then my neighbor gave me a shovel… It’s currently in the shed, leaning against the wall. I’ll figure out what to do about that in the spring.
