bwringer
Ah, I read it the other way around...I thought he was saying that management said that the packout looked unprofessional.
This doesn't require much imagination. It's a silly take.Not trolling, they just don't seem like the right solution for anyone...even in the trades, it doesn't look like an optimal use of space and hunting through stacks of bins isn't efficient.
Who was the idiot that came up with that idea?? And what are you supposed to replace them with, five gallon buckets? If someone showed up to do some work with those cases filled with well organized tools I would be nothing less than impressed. Gouges and dents are part of the deal.Anyhow, lesson learned and I was told to not use them anyhow because they looked "unprofessional" in our work environment.
I might be confused, packouts were not acceptable, or the aluminum cases?We work in a pretty sterile environment, including the customers. Clean epoxied floors, controlled ventilation, everything labeled...etc. etc. It's an image thing. We aren't even allowed to wear baseball caps or hoodies. We have to look the part. Even with banged up metal cases, they are going to not stand out like a big red plastic box. I don't make the rules, I just have to follow them.
I tried my hand at a packout, because it's much easier to roll around. That was until I didn't have to roll/drag around an aluminum case anymore. They are dropped shipped from home to a customer, or from a customer to my next customer.
Milwaukee Packout, Dewalt Toughsystem, Flex Stack Pack, Tekton Stacking...all of them are terrible.
Packouts are not acceptable. But the aluminum cases are our company's standard and should always be used. I did recently find out another reason why we can't use the packouts, they can generate or hold static, and that's a big no-no in our industry.I might be confused, packouts were not acceptable, or the aluminum cases?
Do they make packouts to hold 3 and 4ft pipe wrenches? Still seems like extra trips to me. lokm at the dewaly pic on the 1st page. He putting a electrical box on a stuc. Why would you carry all those charges and drill to that worksite. He better hurry with that outlet so he can plug them in to charge.
Quite a bit. I was a service pipefitter in a service truck. Retired last year.How often are you or anyone swinging a 48? I work in a plant with a lot of pipe and I bet I don't get off two hands the number of times our maintenance crews swing a 48 each year.
This is what I started out with about 25 years ago. They are similar to the higher end musician Anvil cases. I traveled full time with a traditional Platt case for about 8 years. They do get a little beat up, but they never got destroyed. Then, I discovered Harigg Storm cases..i was a road warrior for almost 30 yrs. Platt cases were my go to. Very $$$…. I used ( and still have) the plastic version of this one.
My travel tool case for nearly a decade has been a Pelican 1650. Purchased black, painted white, and it's developed a great patina over the years. It's dialed in for exactly what I need on the road, loaded up hits the scales for air travel between 95-98 pounds, and has accumulated easily 500k miles since 2015.
I like the packout style storage/transport systems for what they are, and we own quite a few. They make sense for lots of applications.
I've read both sides of this debate and I've combined the ideas into the perfect tool solution that makes both sides happy. Stackable 5-Gallon Buckets. Have one bucket for electrical, one for plumbing, one for H-V-A-C and stack together as many as you need for the job at hand. Cheap and affordable. And YES, they WILL come in red!
Snooze and lose my friend
