Fixing a Simpson Amp-Clamp (150) case?
n8n
Curtis Bay, MD
Good evening all
Last weekend I found a Simpson 260-6XLPM at Value Village for the princely sum of $7, including probes (but the alligator clips were missing, so there's a reason you can't absolutely hate me.) I cleaned it up, replaced the one destroyed D-cell battery terminal, bought some new batteries, and it works (I actually had a couple extra battery terminals left over from ~7-8 years ago when I fixed up two 260-8Ps.) It even had the correct fuses in it which has to be a first for me! Because it is a Series 6, however, I couldn't use the Simpson 150-2 amp-clamp that I have for my Series 8 meter, the reason being that the Series 6 has banana jacks on the front and Series 7/8/9 have reverse bananas. So the amp-clamp would work, but only if I had a different style cord to connect it to the meter. Well, I found a "broken" 150 (older) amp clamp on eBay with the cord I needed for low $$ and it showed up today. Thing is, the only thing broken about it is the three posts on the front plastic cover that the screws that hold it all together screw into. I'm thinking that this should be fixed, but how? Maybe something with epoxy and some aluminum or brass tubing from the model section of the hobby shop? What would stick to the case? I see that as the biggest challenge here. I'm thinking to try something like JB Weld or PC-7 but I am not super confident. It's a hard black plastic, the manual says it's Lexan (yes, I got the manual, I need to scan it for Simpson260.com as they don't have it) Any advice would be greatly appreciated as I'd way rather fix this and have another useful tool, even if it is literally as old as I am (the date on the manual is the same year I was born)
I also have a pair of the alligator clips coming so now I need to decide what kind of case I'm going to use for all of this. I did get a big Pelican case a while back with no foam at a different thrift store, I'm thinking maybe I'll get the foam kit for that and then make a case with the meter, probes, amp-clamp, and maybe one of those splitter tools, it may be big enough.
N
n8n
Curtis Bay, MD
On reflection, I'm thinking a solvent? Would micro-mark same stuff work? Then if there are any pieces missing I could fill that with epoxy.
N
n8n
Curtis Bay, MD
Get someone to 3D print one for you? You might find plans out there already.
This one looks brand new, I just need to figure a way to either put the shattered pieces back together of the "pegs" that the screws screw into, or else make new ones but have a secure method of gluing them onto the piece.
N
n8n
Curtis Bay, MD
Well I got a reply from Simpson with the part number for the case half - it's less than $8 from Newark so I'll just add that to my order.
I really do like fixing up old Simpson stuff, their tech support is good with providing part numbers (why they don't put them in the manuals anymore I don't know, but at least for older stuff you can find a lot of them from simpson260.com) and often the replacements are quite reasonable, e.g. I will probably order new knobs as well as the alligator clips and the 150 case half because they're cheap and it'll make stuff look nice.
