I am looking at building a car rotisserie starting with a pair of engine stands.
The car in question is small and light (Porsche 914), and if it works well may get used for other small cars.
My question is how to solve the issue that engine stands tilt upwards slightly, where as I need the rotisserie really needs the two end 'bearings' to be parallel the ground.
My first thought was to cut and reweld, or cut partially, bend and brace the upright of each stand to make the fix.
A second though that came to me is to raise the rear by spacing down the rear wheels to make the adjustment.
I am not sure how much I would need to raise it. I just go the stands so I can put one together and get measurements.
My concern with this is even if adding blocking to the rear wheels is easy, the wheels will now be sitting on swivels that are not parallels the floor.
This would make then 'favor' one direction, or worse yet not turn at all.
OK, now tell me I am crazy, or make some great suggestions.
"And Discuss!"
"And Discuss!"
