Show us your welding projects
zmotorsports
Northern Utah
My buddy had a 'production' motorcycle hauler and got rear-ended. It was easier to build another one than to try and fix the old one. Funny thing is, the welds on his original one are welds I would never leave my garage for something used to haul like that.
Nice job.
I know what you mean about some "production" welds. I was packing the wheel bearings and undercoating my FIL's travel trailer a couple of years ago and decided to give the undercarriage a once over. I was amazed at the piss poor quality and quantity of the welds holding the spring shackles to the frame. Something like that would never have even left my shop.
Mike.
HellaFab
Kingston, Ontario
Had a good day of welding.
One of the pics I happened to snap of me welding the tip to the adapter.
Straight pipe for the women [they like it loud ;) ].
Jersey Tom
Just a simple start - TIG cart. All 0.065 wall 1" square tube and 16 gauge sheet, mild steel. Painted it with Rustoleum "Safety Blue" which I feel like is a pretty good match to "Miller Blue."
For the first time doing any TIG in 6 years (and only a little over 1 year of doing it back then) I feel like my beads are at least decent. Been much more **** about fit-up and clean work pieces, and much more deliberate in my torch placement and pedal usage. In the past I used to just go "wide open" on the pedal and zip through tapping away with the filler rod... came out decent, but more ripply than "stack of dimes" and would wander a bit with position and bead diameter.
zmotorsports
Northern Utah
For the first time doing any TIG in 6 years (and only a little over 1 year of doing it back then) I feel like my beads are at least decent. Been much more **** about fit-up and clean work pieces, and much more deliberate in my torch placement and pedal usage. In the past I used to just go "wide open" on the pedal and zip through tapping away with the filler rod... came out decent, but more ripply than "stack of dimes" and would wander a bit with position and bead diameter.Quote]
Looks good. I think that is the same color I used when I fabricated my welding table to get it as close as possible to Miller blue.
Mike.
F-117HWK
Virginia
Possibly a dumb question, but what would cause the metal to "sweat" a black liquid when welding to it?
I was making the attached last night and was having a bit of trouble. I was thinking it was possibly the two different types of metal between the gears and the little posts I had lying around, but thought yall may have some more insight. The welds were hideous compared to what I was laying down on my welding cart. I was not getting very good penetration on the welds either. :sad:
madosta
Whoa those are some sweet gears. They definitely look hardened and chromed maybe. That is most likely what's causing you to not penetrate.
brawls43
Minneapolis
They kind of look like the gear rotors for an oil pump. Could have been submerged in oil so long that despite looking clean, had oil in them. Which could leak out when heated and contaminate the welds.
F-117HWK
Virginia
Thanks, buddy grabs them from the scrap pile at work for me to play around with. This is what I was leaning towards on the penetration not occurring. Is there anything you can really do to avoid this, besides not using that type of metal?
Almost positive that is what these came out of on a diesel truck as they were contained withing a larger gear which had the teeth on the inside of the circle. I cleaned them before welding, but I never even really considered the oil having penetrated into the gears over time. Thanks.
PM = Powdered Metal
Can you elaborate?
Thanks all
Heavy Metal Doctor
Mason Dixon Line
For ^ I don't have any explanation, but I can tell you I get the same thing -- odd welds / leeching **** -- happen when I weld to a bearing race to get something to grip and pull it from a blind hole. Not sure if it the plating or heat treating or a combination, but its those kinda heavy duty parts that do it.
F-117HWK
Virginia
Interesting. Thanks, glad to know Im not the only one seeing this.
Wiki is probably better at explaining than I am:
http://en.wikipedia.org/wiki/Powder_metallurgy
Basically it's the same process as used to make Oilite bushings. I believe it might also be used to make Gerotor oil pump rotors as well.....just a guess.
Cool thanks for the reading material.
HellaFab
Kingston, Ontario
SO pumped with how the intake pipe for the turbo kit im building turned out.
for those of you not subscribed to my facebook page, here is a pic. couple more on my page.
The customer is getting excited to say the least....
larry4406
Northern Virginia
Here is the rotissorie I built.
Features include: (1) arbor locks with spring loaded pins where the pin handle holds the pin in the retracted position for one man operation; (2) hydraulic jacks for raising but hitch pins in double shear to ensure arbors are concentric; (3) bushed center of gravity adjuster to raise or lower body to adjust for balance (use deep well socket and impact gun on coupling nut); (4) caster wheels with brakes at all corners - I used an oil pan drain bolt to lock wheel at 90 degrees; (5) push handles on both ends.
A fun project that is getting its use now.
aggierailroad
Houston, TX
Here is some of mine, I am a total amateur welder. Will not show close up of welds especially after ZTFAB.
Looks great to me, it is an art in itself to weld fencing flat and square, especially on pieces that fit together like you have to do! Keep up the good work!
st cloud rustoms
Saint Cloud, Florida
A friend of mine kept getting machines stolen off of his landscape trailer, so I built him a locking rack. Turns out, a lot more people want them so now I build one every once in a while and sell them on CL.
03protege
Louisiana
Thanks, buddy grabs them from the scrap pile at work for me to play around with. This is what I was leaning towards on the penetration not occurring. Is there anything you can really do to avoid this, besides not using that type of metal?l
You can bake the oil out, if you have a "crawfish" burner just throw it on top and get it cooking. May take some experimentation but I would think you could sweat it out in short order.
larry4406
Northern Virginia
Larry, thats one hell of a nice looking rotissorie.
Thank you.
I studied many designs out there before building this. Most suffer from lack of keeping the arbors concentric which basically creates a bent crank and impedes rotation. I wanted to ensure concentric axis of rotation yet be able to tune the offset to get the car's CG on the axis of rotation which then balances the body. The nut and pneumatic impact make it quite easy. The hitch pins keep the axis of rotation in alignment without stress on the jacks
My welding skills still need great improvement.
bsaint
Manchester, CT
Well I am fabbing up a cart for my oxy tanks and when I fitted the wheels I found a design error. So I programmed up some tabs to fix it.
Original location.
Bracket from 12g mild steel. I formed it also in a vise.
Welded them on.
That's better!
Now to fab up a tray and tank bar.
NASTYZEN
St-Colomban,Que. Canada
Last weekends project that degenerated to 35 hrs labour....
Electronic weight scale platform. Mainly 2 x 4 x 1/8 Alu. tubing
The racing guys use it to set there corner weights.-
:beer:
zmotorsports
Northern Utah
:beer:
Nasty, I don't know what to say. Beautiful work as always. You never cease to amaze.
Mike.
Black Sheep
Manchester, MI
Here's my cart I just finished for my new toys...
E.rodz
st.paul MN.
started this project years ago still trying to figure out how many more things I want it to be used for. so far English wheel,10 gauge nibbler,rivet driver,still coming up with more parts to use it for a powered bead roller I would really like to finish this things soon so I can paint it.IMAG0525.jpg
if anyone has any more ideas as what else I could use this for please let me know!
ert01
Looks good! I made one very similar but I have my plasma up top and the 211 on the bottom.
You can buy plastic end caps to fit in those open holes in your square tubing. I buy mine on eBay all the time for dirt cheap. Helps clean up the final product.
Black Sheep
Manchester, MI
Thanks! I thought about mitering the corners but then I realized the nozzle for the welder fits in there. I figured I'd leave it open so I could stick it in there when I need to set it down for a sec. However, after helping my dad clean out his barn yesterday I found a nice chrome handle from a tool box that will serve the same purpose so I'll have to look for some of those caps.
IMCA38
Bennet, NE
Dad and I were at Northern the other day and he was looking at their timberjacks as he has several trees to take down this summer. I told him to save his money and I'd make him something. Here's what we came up with, sorry for the poor pic, its been raining all day and all night, so it was cooped up in the garage.
