the type of this screw
force1711
hello everyone.
i have a chair with this screw.
i want t open it, buy don't know what is the type of this screw.
i added here the picture.
can, somebody, kindly let me know what is the type of this screw?
many thanks in advance.
F
force1711
many thanks for the quick reply and want to help.
but, its not show, head torx, like the picture that i added.
many you have another idea, which type of screw this in the photo that i added?
its not like any screw that i know, and it's a long time that i searching the match screw.
dnschmidt
Phoenix, AZ
It's what's known in the woodworking world as a combination screw. It's really a Robertson #2 with the ability to be driven or removed by a Phillips in a pinch. They actually make special combination bits that combine Robertson and Phillips features for driving these screws. It's more of a Robertson than a Phillips so start with a Robertson #2 as it will fit better.
F
force1711
many thanks for your replies.
as i know the Roberton is simply square.
but this one, is a square with a 4 "slots" in the sides.
i found this one:
its like this.
which screwdriver will be perfect to open theses screws?
i don't found the matched screwdriver for this.
sorry for my poor english.
BrandonV
Arizona
i found this one:
its like this.
You can use either a #2 Philips OR a #2 Robertson on that screw.
If you want a combination bit look at Quadrex or Recex.
F
force1711
many thanks. its really Quadrex. but, i don't' find this screwdriver. only bits.
maybe you know, if there is also a screwdriver with this socket, Quadrex?
thanks again.
BrandonV
Arizona
thanks again.
I've never seen a screwdriver with a Quadrex or similar tip.
I would just use a 1/4" bit holding screwdriver with the bit.
F
force1711
the bit Quadrex, are coming with a few sizes, like Roberton, Philips and more, or only with one size?
i mean, this Quadrex, came also with a few sizes, or only one size?
many thanks.
BrandonV
Arizona
many thanks.
I've seen them in #1, #2, and #3 with #2 obviously being the most popular.
dnschmidt
Phoenix, AZ
That's the proper names for the driver bits. They were lurking in the back of my brain I just couldn't think of them when I wrote my reply. I think both Lee Valley and McFeeley's sell these bits.
KnurledNut
n/a
As many here have, I've removed/installed hundreds, probably thousands, of those.
Dont overthink it.
Either a square or crosshead driver will work just fine.
Combo head screws have become the norm in a lot of manufacturing.
I have Quadrex bits and in real world use, the advantage is hardly noticeable. They are usually not great quality and wear fast.
Get a high quality □ or + driver set if you dont have one. Either will be far more useful than a dedicated subpar bit.
F
force1711
Dont overthink it.
thank you very much for the help.
i have the square Roberton bits.
are you can recommended for a high quality screwdriver with a Robertson slot?
Milwaukee, Stanley, or wera? or maybe you can recommended of another brand?
thanks a lot!
dnschmidt
Phoenix, AZ
Obviously, ROBERTSON. These can be obtained from McFeeley's. The true Robertson screwdrivers, like their bits, are two piece affairs with a hardened tip inserted into a steel plated shaft. Here is a link:
F
force1711
and what is the different between the Quadrex vs the recex?
