Not another scan tool thread!!!
Ohmthis
Outside of Louisville KY
I’ve been looking for a newer scan tool. I was wanting a bi directional tool, but with the advent of electric parking brakes, electric steering, and a plethora of body modules I believe I’m wanting more as well. I want the ability to reset the ecu/pcm/tcm or other transmission control units. If a TCM/transmission is repaired or replaced it usually must be reset (I don’t want to call it reflashed, but I’ve heard it referred as that). So, for those that have a vast knowledge of these tools, what am I looking for? I have an Autel 619 that has been a great tool, it’s just time for an upgrade. Thanks guys
Wrench97
Southeastern Pa
What brands and models do you mostly work on?
Snap On if your in the business, Autel is a good tool also for DIY take a look at the MS808S
BrandonV
Arizona
What sort of vehicles are you working on?
I only buy Hondas so buying a dongle for $300 and renting the software for a day every now and then is the best solution. Some brands work like this others pretty much force the DIY community to resort to 3rd party tools like the Autel 808.
O
Ohmthis
GM and ford right now! I’m not opposed to a 3rd party tool, i Just need to know which one. How do you “rent” the software? And how do you connect the dongle, laptop?
BrandonV
Arizona
So, in the case of Honda the dongle I found used on eBay for $300-400. Honda for $45 gives me 1 day access to i-HDS. Dongle plugs in via USB and you download i-HDS from Honda.
If you need access all the time this method is probably not great.
For Ford I would look at FORScan. It should do everything you're looking for way under $100 (dongle & software). FORScan has almost all the capabilities of the Ford diagnostic system.
ZRX61
Solar Blight Valley, SoCal
I just bought & returned an Autel 619. They advertised that it worked on 2023/2024 models. Truth of the matter is that useless POS didn't work on ANY vehicle made 2020 & later... and neither did any other scanner advertised for 2023/2024 vehicles on Amazon... unless I wanted to spend 4x as much.
Didn't help matters that Autel's website is such a shitshow that it informed me that my ******* name wasn't a real name when I tried to download a manual for it... which it turns out, wasn't listed on their website anyway.
BrandonV
Arizona
If you don't mind me asking where did you buy the unit from? An authorized Autel dealer or somewhere else? There are a lot of gray market units which are questionable at best.
O
Ohmthis
My 619 is well over 10 yo, if not older. I have done an update or two throughout the years and that has helped it. It’s a great ”basic” scan tool. There are easily cheaper alternatives.
ZRX61
I have an Autel ML629, which worked just fine on the '11 Camaro & '04 Accord, but can't talk to a 2020 Explorer. That 619 I just returned was great on the Accord, did much more than the 629..... But I need something that can talk to the Explorer.
BrandonV
Arizona
Bummer. I really like FORScan for any Ford. Actually feels like I can do "real" things.
2ndGearRubber
Pittsburgh
Topdon phoenix lite 2 is about as cheap as you'll get into a "known name" bidirectional. https://www.aeswave.com/Topdon-Phoenix-Lite-2-p10173.html
For my money if sticking with Autel you want the 906-pro models, the old 906 platform is pretty dated by now.
Reflashing software, modifying it, is another tool/process entirely. Look into whether you want to simply clear adaptives/learned values via a scan tool, or actually VIN match and initialize blank TCMs. You can initialize -some- modules with a scan tool. It's documented pretty poorly as to whether it can be done or not until you plug in a scan tool and try. There is some..... trouble brewing related to AutoAuth and tools that don't fall under the big names of Launch/Autel/Snap on. My topdon works fine with Autoauth, despite there being concerns/issues about tools working properly. The Phoenix lite 2 is CanFD/DoiP compatible. Consider CanFD/Doip depending on what you work on.
I have an older Autel 906, the phoenix lite 2, and a snap on zeus. They're all great tools, and they all let you down. I mostly use the Zeus and Topdon, autel is older/slower and has a cord. Topdon is my favorite for service functions like oil lights, parking brake, etc. Very fast boot up time. The snap-on is admittedly my first grab otherwise.
srs2000
Awesome. I've spent a week checking out different android apps and none of them are remotely comparable to even the demo of forscan. Even works with my current BT dongle. Thanks!
BrandonV
Arizona
FORScan is downright amazing for the cost. Unless you're doing serious module reprogramming and the like almost all the bidirectional things the average DIYer wants to do is available with a few clicks.
bobio
I have had this Actron Pocketscan for years. Does everything I need it to.
ZRX61
It's on the "at some point" list, the hold up is getting a cheap lap top to install it on.
srs2000
$7 for the phone app.
I think it can allow me to do everything I will ever need to on this particular car (25 years old) but I'll try the computer program in the near future to see. Getting sensor voltages was what I was after and its giving me that and way way more. I also can bleed the ABS pump which I was expecting to have to get done at a shop.
Definitely glad I checked this thread. Best $7 I've spent.
O
Ohmthis
2nd gear, I’m not sure what is done. I’ve taken 2 fords and a GMC to have the tcm “reset” after replacements of transmission and /or techm/tcm. I’ve paid roughly $600 for this service. If I’m planning a new scan tool, why not grab one that will save me the time and money to “reset” it myself. Thanks for the info.
