How to adjust kettle thermostat on a popcorn machine.
Denwood
Thunder Bay, Ontario, Canada
I posted this up in my thread, but am throwing the information here for google. I found various bits of information on adjusting popcorn kettle thermostats, but none that bring everything together. Hopefully this helps someone out there :)
Problem: I noticed, after a few batches on this new machine, that the popcorn was chewy and yields seemed low. Additionally, quite a few un-popped kernels were left in the kettle. The kernels looked slightly burnt and were partially split.
Solution: Kettle temperature needed to be lowered.
It took me some experimentation and reading to figure out that the kettle temperature was actually too high. The manufacturer did send me a guide to adjust but honestly, it was useless, aside from the fact that they confirmed both thermostats need to adjusted together. There was no indication of a target temp. They did advise that boiling a cup of water should take 3 minutes, but this tells you nothing if the thermostat is set too high..it just confirms the element is working. Guessing the temp is potentially dangerous as once you get into the 500 F range, an oil fire could occur. The factory setting was too hot by about 100 F. Turns out popcorn kernels like to pop around 360 F (180 C) according to some published science experiments.
How to adjust the kettle temperature thermostat on a Great Northern Popcorn Machine:
The "kettle" has an inner pot (which integrates the element and thermostats and an outer pot which are easy to separate with three top mounted bolts. Removing the kettle entirely from the machine makes it much easier to test.
76cb9a67-4167-43fc-a733-5e282c3223dc-jpeg.1849603
I removed the kettle from the machine, placing it on a silicon oven mitt, and plugged it directly into the wall. The power meter here shows 5.66 amps used by the element. I used the EM100 as it is easy to see when the the element thermostat cuts power to the element. While testing, the inner and outer pot will be sitting loose, so you need to take care as there are live wires in there!! Unplug it before adjusting the thermostats! Both thermostats should open (either one of them opening will cut power to the element) once the element has reached its temperature set point. Then they will close (sending power again to the element) once the kettle temp has cooled 20-30 F.
My trusty Fluke 179 (an awesome tool!!) came with an 80BK-A thermocouple which worked well to check the temps of the kettle base. I tried an infrared temp gun which read 100 degress too cold...so I would not use one to test. It took me quite a few tries and popcorn tests to figure out that the ideal temp for the element to cut off was about 395 F (200 C) as it cools to just below 360 F (180 C) and then cycles on again. This keeps the kettle in that "magic" 360 F range for popping.
There are two thermostats on the base, which I'm guessing is for safety (vs using a thermal fuse) but they work a bit differently. One "pops" on and off with an audible click and the other has contacts which move slowly. I set the slow contact thermostat a bit higher than the "pop" version (on the right side of the pic) as I assumed that one is the safety backup. 1/4 turn will adjust about 40 F.
I should note too that if the ceramic insulators on your thermostat (there may only be one thermostat) are white, that the increase/decrease directions are opposite to what you see in my picture below.
rrussell50
Great post, I just found this after seeing it on Amazon. Just a few questions, if I just starting playing with adjusting mine, from cold I hear the first pop around 430F when the amps goto 0.00 ( The second time the pop turns back on the temp is around 330 degrees making the entire range. 430 F - 330 F. When the heating element turns back on it only goes up to approximately 400 degrees and then shuts back off at . Giving those ranges I should move the right control 1/4 clockwise to lower the temp and the left control 1/4 counterclockwise?
Thanks
D
Denwood
One of the thermostats is a safety, so adjust one so it is remaining on(maybe 1/2 turn counter clockwise) and then tune up the 2nd for your actual cut off. Once you are popping great, then adjust the 1st so it is cutting off just after the 1st. It’s too hard to adjust both at the same time.
Temp cutoff will likely be different temps after your first cycle due to heat soak.
Both thermostats in my unit have the pink insulators so it is counterclockwise on either of them to increase temp cutoff. Note my comments on their operation…one clicks audibly, the other does not.
gunkulon
Thank you!!! I bought two PopMaxx 12/14 oz popcorn machines from a dude for $120. I cleaned one up and tried it, popcorn cooked super fast, came out chewy styrofoam. Tried different kernels, then tried the other machine, same thing. Searched for solutions online, nothing helped. Found this post, lowered the temp on one of the kettles, MUCH better- just about perfect! Thanks again!
mm08822
Awesome...I'm glad the information helped. I normally only fire up these posts when I am frustrated searching up information on a subject, so it's nice to hear that you found the thread useful.
Nice write-up. :thumbup:At least it was for a rewarding purpose.
SunnyDU
Thank you so much! This was a game changer. Went from overcooked, underpopped and chewy to nice and fluffy with way less unpopped.
Few notes from my experience.
- I couldn't get a good temp read from putting my probe on inside of the pot. I used a mix of IR on a burnt area in the pot and the probe on the underside next to the thermostats. You can actively catch the low end temp as it cools and adjust the thermostat to roughly the low temp around 330.
- I left the safety one alone since the main temp was too high anyway.
- The ground was disconnected from the outer pot. Seemed like a fragile connection. I'd check your ground to endure it has a solid connection.
tlkudo
Had the same problem with the same Great Northern 8oz popcorn machine - smokin' hot kettle with insta-pop chewy popcorn. While it was nice being able to make a full batch of popcorn in 60 seconds I prefer my popcorn to be crunchy so went down the rabbit hole of how to fix this thing...
I eventually found this thread and tried adjusting my thermostat. No dice - the one that came with my machine has a 200F range between the set and reset temperatures. So if I set it low enough to not smoke the popcorn it would never actually pop it since it needed to cool down by 200F before turning back on again.
The fix I came up with is simple and cheap - add a simmerstat / infinite switch. Basically turned the kettle into a stove burner. It works great! My machine has 6A of current through the heating element so I had to make sure to buy a 6A simmerstat but that was about it for planning. I've attached a couple pictures - still need to shorten the mounting screws and waiting on a knob but you get the idea. I wired in the simmerstat before the on / off switch so I can use the switch light to monitor the burner duty cycle.
I now have perfect popcorn and precise temperature control for about $20.
larry4406
Northern Virginia
Welcome aboard!
informative post. I had to google to see what a simmerstat was.
D
Denwood
Ditto, never heard of one. Thanks for posting up your findings, pics and info :) Can you post more details, links etc for the simmer device?
I did a project to regulate a rice cooker temp pretty precisely using a Zigbee device and temp probe, and vary power to the element to maintain wax in the pot at exactly the set point set on the automation hub control panel. Now you have me thinking !!
This is the vid..same technique would work on this popcorn maker.
Chain Waxing with a “Smart” Rice Cooker
tlkudo
I thought about going down the PID route to precisely control kettle temp, I even had a cart with about $100 worth of parts in it. But then it dawned on me...I don't really care about the exact temperature as long as it makes good popcorn! It took a couple of batches to figure out where to set the simmerstat knob for the perfect pop but now I know - medium high ;)
Simmerstat was a generic Amazon special (again 6A to match my heating element):
And here's the knob that I put on it:
D
Denwood
I see... a simmerstat does not sense temperature at all. It just cycles power based on an internal heated spring element. When doing my wax pot experiments, I did pretty big spikes in temp, unless I ramped power back before the set point was reached. Given the variables in the popping itself, (how much oil, volume of kernels etc) I'm not sure why someone has not come up with a more precise PID driven setup.
So your setup is more or less the analog equivalent of this (which also controls temp, but only via on/off). I like your solution for the KISS factor. :) https://www.reddit.com/r/popcorn/comments/1svq44q
brandobond
Wow, you are a genius! I have the same machine and I’m having the same problem. Sounds like you have the winning solution. I hope you don’t mind answering a few questions.
1) It seems like you did not bother to remove the thermostats from the circuit. I’m assuming that you just left them set pretty high and that they never actually engage?
2) I thought simmerstats only work with 240v power. Did you get a special one? Can you share any details about how you wired it? I agree that right before the on switch is the best place to check that it is working correctly.
Thanks so much for the great idea and any additional help you can provide!
tlkudo
Yes, my thermostats were terrible for temperature control but work fine as a passthrough / safety device so I left them in the circuit, more or less set as they came from the factory
Simmerstats only care about current flow, not voltage. They're rated for up to 240V but you can also use them at 120. The current is determined by your heating element. In my case, my heating element pulled 6A at 120V, so I needed a 6A simmerstat. This is important because the bimetallic strip and control knob cam need to be "tuned" for a specific amount of current to properly cycle. Here's everything you ever wanted to know about simmerstats, including a wiring diagram:
They will have 5 connections on them. L1 and L2 (Line 1 and 2) connect to power (hot and neutral for 120V), the order doesn't matter. H1 and H2 connect to the heating element, again order doesn't matter. P is for an indicator lamp, I left that unused.
Amazon has plenty of 6A models. They tend to be called "infinite switches" so that's what you'd want to search for. Here's one example that's in stock as I type this:
Good luck!
