"If its the whole plate assembly that's leaking where it bolts onto the boiler, it may be possible to reseal it if you can get the bolts out."
Loads of fun. Removed the heat exchange in my boiler due to a boiler plate leak on my 28 year old coal fired boiler and iron oxide build up on the exchange. 6 bolts snapped off out of 12, had to grind broken bolts flat, drill out and thread for new bolts in a tight area. Then the high heat silicone used for a gasket shrank when cool and leaked slightly. Switch over to all heat pumps so I never repaired the leak. Coal *****.
Heat pump water heater....
Have a heat pump water heater and love it. My large basement is unused, 26x50, which has enough floor and wall surface for the water heater to pull heat from, at approx 50 degrees F year round, joist are insulated. As a result the HP water heater is not pulling heat from the living area above it. In most of the usa they should save a few hundred dollars a year
IF you place it in an unheated area, which is not parasitic on a heated area of the home, as in a large unused basement which draws heat from the average ground temperature. HO water heater also act as a high capacity dehumidifier
As concerns bleeding air from hydronic systems your best off getting high capacity bleeders as linked. The small air vents, as usually used, are almost useless, they leak and take much longer to clear the air from the system. I used multiple vents, as linked, on my hydronic system and multiple vents ( water pressure rated) on my potable water piping
This is a Bell & Gossett hydronic air vent. Item Hydronic Air Vent. Connection 3/4 in (M)NPT or 1/2 in (F)NPT. (F)NPT Connections (In.). (M)NPT Connection (In.). If it is not possible we will work with you to resolve the issue.
www.ebay.com
or, newer technology
Find many great new & used options and get the best deals for Honeywell PV125S 1-1/4 Sweat Connection SuperVent at the best online prices at eBay! Free shipping for many products!
www.ebay.com
