Reactive Power
LopezBart
Lopez Island, WA
"Double your voltage, double your flux, double E, double E, double E *****" is what the EEs said when I was in college.
And everyone studied beer - the undergrads, the graduate students and the (younger) professors.
pancho400cid
Austin, TX
I "get it", but I don't agree with it.
Reactive current isn't wasted..... the physics don't work without it. It's the current that goes into making the electric fields in capacitors, and the magnetizing current for electric motors and other inductive loads.
You wouldn't want to live in a Watts-only world.
pancho400cid
Austin, TX
I hear ya... I just don't agree with the term "wasted" . What the KVARS are doing is just as necessary and useful as what the Watts are doing. The magnetic fields of a transformer are just as necessary as the turning shaft of the motor it's powering.
You can do on-site power-factor correction and get by with smaller transmission lines to the site.... but you can't eliminate the reactive current. It's gotta come from somewhere. Fortunately, as you said, in a lot of cases, a few tens of thousands worth of power-factor correction capacitors, etc. can sometimes eliminate the need for much more expensive transmission cables and generating capacity.
ArcReactorKC
Out in the county NE of KCMO
I have spent hours attempting to educate data center stationary engineers on what Var really is and why they need to care. They always bring up the beer mug analogy but then can't extrapolate that to their gear and systems.
exranger06
CT
I agree that reactive power serves a purpose, and we do need it, but IMO, that just makes the beer analogy even more accurate. Obviously you wouldn't want a beer that's mostly foam, but you DO want at least a little foam on top (though I guess it depends on personal preference). The foam helps bring out the flavor and aroma of beer, and reduces the carbonation, which makes you less bloated. So:
No foam, all liquid beer : no reactive power, all real power = bad
Lots of foam, little liquid beer : lots of reactive power, little real power = bad
A little foam, mostly liquid beer : a little reactive power, mostly real power = good.
LopezBart
Lopez Island, WA
The beer & foam example is how we explain it to the mechanical engineers I work with. The rest of us use trigonometry...
As an ME I always thought of this as the phase angle between the voltage and current, but perhaps some are happier with the beer analogy....
D
dave*99
Coastal NJ
Engineers use I for current and j for complex numbers.
Physicists and mathematicians use i for complex numbers.
Debcrow
New Mexico
The mug is used to transmit the beer from the tap to you, the consumer.
Plugging your lips on the edge and tilting, it is distributed to your system for its intended use.
After consumption, you are pretty much going to track a sine wave as you walk.
electricity, Elementary Watt's On.
I know, we need a 'groan' icon :)
mark-NJ
new jersey
I'll be "Team E" until I die...(but I'm old! :) )
EDIT: maybe it worth also mentioning: ISO uses U for voltage. Add that to the pile...
MBfreak
MEMBER EMERITUS
Linkoping , Sweden
Being a firm believer in understanding the math and physics in electrical circuits I believe that
being able to calculate a circuit before tearing into it, is the way to go. For DC static circuits quite easy.
For switched DC, some understanding of Lenz law and derivate calcs help a lot.
For power frequency circuits where currents and voltages are reasonable you need a solid understanding of "j" ( math guys use "i")
and symmetrical components.
For obscene voltages and currents ( like 1050 kV AC in China) or 970 kA at 25 kV short circuit currents in a large nuclear power station
you need a bunch of people with varying skills.
However, electrical power circuits are mundane for the math lovers, most everything can be calculated with reasonable skills and accuracy.
This is sharp contrast to calculating air flow around an object at Mach 3.
Ola
