Vulcan Omnipro 220 Welder
Mgdoug3
KY
I like to look at the one star reviews when looking at something from Harbor Freight. You have to select 1 star review because HF only show 5 star reviews by default. The reoccurring theme with the 1 star reviews is that once the machine quits, you scrap it because no parts are available to fix it. If you decided it's worth the gamble, get the 2 year warranty and hope for the best. If it's on sale, there's a good chance it's being dropped or replaced with a newer model. I'm not sure how the 2 year replacement warranty will work if it's no longer available.
Me personally, I would rather buy a different machine that can be repaired and not a throwaway unit.
driftpin
What is 'half-price?" Half of $1150, or $1100? I think I had a box in my truck when they were $900. I had filed for the class-action lawsuit, and because I had original receipts for my purchases, I got something like $400 store credit on two cards. I used that to buy my unit.
If you can get it 'same-as new' with all the cables there & etc, for something like $500-600, I'd suggest you consider buying it.
You might want to check the paperwork as there's a coupon in there for an accessory. The box doesn't come with a spool gun, and I think no TIG torch, so one more reason to check what's there in the returns/open box table. Maybe the prior customer bought accessories, and they got stuck in the box too.
If it has all the accessories, buy it, if you have the $. Download the instruction manual before you return to the store and take inventory of what comes with the box, so you can check things off as being there (or not).
If you buy it, take it home and try it out to ensure it's functional. It works on 120/240V. There should be cords for both voltages; a gas regulator, a hose from the regulator to the machine, a ground clamp which appears pretty meaty, and the MIG wire-feed torch.
Take a look and see what spool is on the machine, I bet it's the flux-core wire for 'no-gas' welding. See how-much wire is still on the spool, and compare that to a spool of the same weight/size on the shelf, to determine how-much use it got before being returned.
I have one, and while I'm not much of a welder, I let an acquaintance use it to do some welding for a car project, and before he started, he poo-poo'ed the idea of working with a HFT welder. He brought some #5 re-bar w/him, to test-weld, and the machine did a good, quick job, so he set it up for the welding of engine mounts to the frame. He went to work, and worked continuously, until two motor mount blocks were done, and the brackets for the transmission mount was, too. He never had to stop because something tripped (we had it wired to a clothes dryer 240V outlet). The machine never shut-down because the duty cycle was exceeded.
At the end of the work, he said, "I would use this box, any time!" He is a professional welder. Work was steel, MIG & Ar gas.
I also have the TIG torch, and it comes with the cord for a stick welder. I also have a HFT spool gun for welding aluminum, using this machine and I've used that a bit, but I'm a novice and still learning.
Here are some pics of his work (the guy who helped us with the car chassis).
Nomad engine mount weld Left.03.pngNomad engine mount weld Left.04.pngNomad engine mount weld Rt.02.pngNomad engine mount weld.03.pngNomad engine mount weld Left.02.png
Here's the box on a HFT cart. I have both Ar and Ar/CO2 gas bottles, which I own.
The screen when he was doing the motor mounts.
Who noticed the welder's car in the background? It was a cool ride, an LS V8.
dnschmidt
Phoenix, AZ
I like HTP but a lot of people like the Vulcan welders. Parts availability always concerns me and that's my issue with Vulcan. If I were considering a welder from China like the Vulcan I would go with Primeweld. Their customer service is out of this world. I bought one of the MiG 180 machines and for the money it's amazing. It's not my ProPulse 200, which I consider to be the absolute bomb, but it didn't cost $2,000 either.
Wamsutta
Amarillo, Texas
You're kidding right? They actually named it the 220? Not only did they copy the cabinet style, they had to copy the name too.
P
PearlWhiteGT
South Texas
$571.99 to be exact. I'm considering going back and opening up the box to check on all the things.
dnschmidt
Phoenix, AZ
I am seriously thinking about buying one of these as well. I would get it for that price
For that price if it blows up in five years who cares? It always comes down to value for money. If it's cheap enough and does the job parts availability down the road is less of an issue. By then you might have gotten tired of the orange color.
pancholasvegas
Not the OmniPro, but I rolled the dice on a HF ProTig 205 on an open box sale. At the time, they were $1,200, and the open box sale let me leave with it for under $700. One of the best purchases that I've made. I wouldn't have any hesitation grabbing this one if I was in the market, especially for open box pricing.
