Another new Tekton product
Steve_P
Strange. Not sure the purpose of this one, although I'm sure someone will dream one up and post one in a minute. If you are going to introduce this, it seems like a 1/4 drive would be the most useful? Not that I would buy it, but.... This one goes in my WTF file with their last weird folding ratchet contraption.
A real simple product to introduce, that I'm not sure if anyone else sells, is a set of 1/2" drive impact extensions with the shaft diameters of a 3/4 drive extension to reduce torsional losses. That I will buy. Not this. Edit- and yes, I know I can do this extension with adapters.
KnurledNut
n/a
Because a set of these... ontent%2fuploads%2f2014%2f07%2fFacom-Angled-Wrench.jpg ...takes up more room than a single L handle that complements existing sockets.
It would be beneficial if Tekton offered this in 1/4 drive.
I have a custom 1/4 drive L handle bent out of an extension.
I also have a small 90° 1/4 drive to hex socket adaptor that I keep with my bit set.
BDT/NWMN
Erskine, Mn
Lardy1, Thanks for posting these TEKTON socket handles. These are available in 3/8" and 1/2", and I will be promptly ordering both. There are many times My nice breaker bars and numerous ratchets are simply too fat and clunky to access fasteners in cramped quarters, where these handles would more likely fit. Again, Thanks.
Etchase
Hawaii
I wonder if they could make these in hex drive and release some hex drive sockets too. Stronger, and improved access in tight situations. I think it would be innovative.
Grokew
Home
It could be more flexible/ useful, if they also had the wobble tip at the bent side (especially if it was available on 1/4 drive).
Edit: So many early Snap-on references and jokes. Snap-on did have a pretzel shaped handle, they just needed to twist it a bit more
Mgdoug3
KY
An actual socket wrench is more handy to me since one end is a pass through design. I bought a 9/16" Facom wrench for one specific job and it works great. The Tekton bent extensions can't do anything my other tools already do and I have no interest.
JradM
Alberta
I first thought this was for clearance - so you could get underneath something at an angle.
If that's the case though, it could be a lot lower profile if instead of bending to 90 degrees, it was just a square drive welded to a straight handle.
Now I'm stumped. Someone show me what this does that other tools can't.
dscheidt
one of the places I've seen people using tools like this is assembling C-channel structures. The L gives enough clearance for a socket to fit the nut or head of the bolt in the C-channel. There are some other situations where a fixed socket wrench is eaiser to deal with than a ratchet, low clearance or tight spaces.
Black300zx
Elkton, Md
I got the email as well. My initial thought was that they could be useful for an emergency tool roll type situation where you might be worried about a ratchet rusting up. For instance - an emergency tool roll that gets stored on a boat. Not efficient to use regularly, but dependable and cheap for cases where you just need to be able to turn a fastener to get out of a jam.
dscheidt
So, I bought a set. They're really nicely made, and I will probably never use them. I could see someone who needed to fiddle with small engine spark plugs all the time sticking the socket on the 3/8 one, and sticking that in a pocket. There are probably other low torque, but tighter than finger tight, applications, too, but I can't think of any. The thing that gets me is that double end L socket wrenches aren't new, they were in all sorts of cheap socket sets too cheap for the crappiest ratchet in the 50s to 70s. They disappeared after that, as far as I can tell, except for big ones sold as breaker bars. So did some bright bulb at Tekton think "you know, all they really needed was wobble!'? or did they see a demand for these things? Or did they see it in a supplier's catalog, and think there are enough suckers like me around to make it worth while? (being in the catalog implies there's some demand for them, though...)
bigfunwmu
S. MN
There are a bunch of "mechanic" videos on youtube with dudes from India rebuilding equipment in the dirt using socket drivers like those. I see the idea, simple and functional, but I have lots of other options since I'm in America and can afford other stuff.
Callelle
Depew NY
I wouldn't be surprised if they had a stock pile of extensions that didn't make a QC and someone thought "hey, instead of destroying these and losing money, let's put a bend in them and sell them as the hip new thing". Cause let's be honest, these things are esentially useless or there are better options for what they do (aka: An actual breaker bar, which hardly anyone uses anymore as well)
^ I use a breaker more than I use a ratchet. All depends upon what you're working on.
I want a 1/4" drive "ell" handle. I sent them a note but they didn't reply.
mike93lx
Richmond, VA
this may or may not be a complete and comprehensive list of U.S. based twist drill manufacturers. with the exception of Century, these are all manufactured in the U.S. to the best of my knowledge:
Brocas / Brocas Minnesota, 1 Southwest 7th St., Chisholm MN 55719 / https://triumphtwistdrill.com/home/brocas-minnesota-logosm/ / twist drills, punches, taps / see also Minnesota Drill, Triumph Twist Drill, Northland Drill /
Century / Century Drill & Tool Corp., P.O. 5216, De Pere, WI 54115-5216 / https://centurydrill.com/ / est. 1940 / distributor of outsourced products - not a manufacturer /
Minnesota / Minnesota Twist Drill Co. Inc., 1 7th St SW, Chisholm, MN 55719 / twist drills, punches, taps / see also Brocas Minnesota, Northland Drill, Triumph Twist Drill /
Norseman / Norseman Drill & Tool, 355 State St., St. Paul, MN / http://www.norsemandrill.com/ / twist drills, reamers, taps, cutting tools / see also Viking Drill & Tool /
Northland / Northland Drill, 1 Southwest 7th St., Chisholm MN 55719 / https://triumphtwistdrill.com/home/brocas-minnesota-logosm/ / twist drills, punches, taps / see also Triumph Drill, Brocas Minnesota, Minnesota Drill /
Rocky / Rocky Mountain Twist, 34837 Innovation Dr., Ronan MT 59864 / "Montana Brand Tools" / https://www.montanabrandtools.com/ / est. 2001 / twist drill bits, 1/4" hex bits, power tool accessories /
Snappy / Snappy Tools, 1009 No. Hwy. 377, Pilot Point, TX / https://www.snappytools.com/ / est. 1962 / twist drills, countersinks, cutting tools /
Thompson / R.W. Thompson Inc., 3715 Harrison Rd, Ste. 500, Loganville, GA 30052 / https://knkut.com/ / est. 1982 / "KnKut" twist drills /
Triumph / Triumph Twist Drill Division, Minnesota Twist Drill, 1 Southwest 7th St., Chisholm MN 55719 / https://triumphtwistdrill.com/ / twist drills, punches / est. 1952 / incorporated Jan 01 1961 / see also Northland Drill, Brocas Minnesota, Minnesota Drill /
Viking / Viking Drill & Tool, 355 State St., St. Paul, MN 55107 / http://www.vikingdrill.com/ / twist drills, reamers, taps, cutting tools / see also Norseman Drill & Tool /
I cannot offer any opinion in respect to which brand might be "better".
I appreciate the "Project Farm" videos, but unfortunately more often than not they do not show all of the options currently available (as is clearly evident when you look at the list above.)
I sent a set of the "Montana Brand" titanium hex-drive drill bits to another member for his "Secret Santa" gift, but we have yet to hear any review on the product from him.
As for myself, I finally figured out that buying cheap drill bits is penny wise and pound foolish.
In cases where I know I will be destroying the bit, I'll use anything at hand. (Drilling through old plaster walls or mixed media.)
If I go to a hardware store to buy a drill bit, high-end cobalt will be my first choice. Titanium second. Plain black steel only if they have nothing else.
YMMV
Wrong thread, FYI
dnschmidt
Phoenix, AZ
As the A#1 lover of angled socket wrenches (the whole reason I got into the TOPTUL thing) I'm failing to see the usefulness of these new Tekton releases.
Callelle
Depew NY
I genuinely can't think of why. Breaker ratchets are tough as nails at these points, I just see it as a waste of time to break it, pull the socket off, put it on a ratchet, and then continue. I know it's not the "proper" way, but it's 2024 and these aren't the ratchets from the 50s.
Well.... probably because 90% of the time that I'm using a socket is on a lawnmower engine, so there are not a lot of turns involved.
Rmoving and installing with a 1/4" breaker vs. removing and installing with a 1/4" ratchet = not enough difference to matter and I don't tend to over-torque stuff with the breaker.
It most certainly isn't because I have any shortage of ratchets - my "user" 1/4" set has 4 different ratchets in it, but only one breaker. Go figure, huh? :headscrat
