Please, show your hard handle bit drivers.
So far, I have these 3.
The Malco connext1, and connext2 require powerbits, or you will be cursing, while trying to pull a 1 inch bit from them. They hold the bit firmly, with almost no play. Feels similar to using a fixed blade screwdriver. The knurled area spins, so you can't use it to adjust a screw.
The engineer DST-07 is tiny, and works great for sewing machines. It can use insert bits, and double sided bits, but it has no magnet, and the ball detent it has is way tight. Powerbits fit a bit loose, because the detent seems to fall in the groove, allowing some up and down movement.
Some day, I will get a Vanilla scented PBSwiss.
