Cleaning Impact Sockets
Ser50
Vancity
there might be some electro method,,, im no restoration expert, but recently picked up a used 3/4 universal impact from SO and just ran it through the wirewheel, looks great. a little smoother than original, but...
fr0mastaj
+1 on WD-40. Also what i use. Sometimes the surface rust on my impacts comes right off with just a shop towel.
________
TEEN BRITISH
fourfeathers
QUAD CITIES, IL
A surplus tool seller here had a guy media tumble a bunch for him, and they came out nice and shiny. They are Apex swivels, and look a bit like black chrome.
ryan_289
Arkansas
I usually put them on a ratchet and wrap them with the steel wool and oil and give them several turns holding them tight. I have done it using the impact and bumping the trigger but will not in good conscience recommend that method!!
CamarosRus
Renton, WA (Seattle)
.........and when your done cleaning,
PROTECT from future rust with FLUID-FILM.......
WD-40 is absolute **** in the big picture
of rust inhibitors!!!!!!!!!!
mrholeshot
MEMBER EMERITUS
WD 40 on a shop rag. Hold the rag around the socket and spin it with a impact. Takes 20 seconds to clean one
Indy_500
Appleton, WI
I can't wait to see what my impact sockets look like in 20 years, they look like hell and i've only had em a month
C
chopper1
Member Emeritus
Ohio's North Coast & Florida's West Coast
Well, I started cleaning the sockets this afternoon. It appears that they never had an oxide finish or it was removed during a prior ownership.
Was there a definite purpose for an oxide finish on impacts other than making them easier to spot in box?
tjmonsen5
Crystal Lake IL
I have metric and standard craftsman deep impact sockets. they are all rusty, ive only owned them for a year!! Ill try the steel wool method, but im scared of wearing off the easy read numbers.
rsanter
visalia ca
I dont worry about hutring the coating. I use an impact to spin them against a wire brush and then scotch brite
then I use a gun bluing kit to blue them
bob
lipadj46
Anyone with firearms should have some brand of clp or hoppes 9 around and some gun oil, works great on oxide finishes (like gun bluing, parkerized finishes, black oxide etc).
MrMark
Southern Cal.
The black oxide is there to protect against rust. Unfinished metal would flash over in a day. The black oxide seems to do a pretty good job. Even better if it is coated with a waxy oil-like film like they are at the factory.
I wouldn't want to strip off that film with petroleum distillates. Clean them with a cleaning oil like break-free or WD-40 if that's all you have.
Charles (in GA)
50 mi south of Atlanta
I do not think Apex finishes their sockets with black oxide. The ones we have at work are a bare gray finish. Possibly they have a clear coat over the metal, that is what it looks like.
Charles
