HomeTheaterMan
- Joined
- Apr 3, 2016
- Messages
- 493
I'm trying to do a parasitic draw test and I'm not sure what I'm doing wrong. I'll be the first to admit that I'm not expert with this meter, but I've never had any problem doing it with the Snap On meter I previously used. I feel like I'm doing everything correctly. I disconnected the negative battery cable. Then I connected one lead to the negative battery cable, and one to the negative post on the battery. On the meter side, I hooked the negative (black) lead to the "COM" Port and tried the positive (red) lead connected to both the "MauA" port the second from the left and the "A" port on the left. Then I set the dial to the mA setting, then also tried the uA to make sure I wasn't on the wrong setting. They were both initially on AC power, so I used the yellow button to manually change them back to DC power. Neither setting seemed to produce any sort of reading, nor was the ground to the battery connected. Nothing in the vehicle was getting power. At this point, I figured the fuses in the meter must be blown. However, I took the meter apart and pulled the fuses out. When I did a continuity reading, I was getting a reading indicating they weren't bad. This leads me to believe I probably shouldn't spend the $40+ they cost.
At this point I'm at a loss as to why I'm not able to test for a parasitic draw though. I'm thinking I must have something hooked up wrong or something set wrong on the meter. Any idea where I've gone wrong?
