Unknown steel identification
WhoWhatNow
Collegeville, PA
I have a chunk of steel I want to use for a project. I will be machining and welding this piece. Although it is mildly rusted, the clean surfaces have a very shinny surface. I am thinking it is some type of tool steel. How can I determine if it is machinable and weldable before I put ton of time into the project? It throws bright orange sparks when hit with a grinder.
pamike
Central PA
Higher carbon steel will have more of a star burst type spark vs a low carbon mild steel where the sparks are more straight line. I would compare the sparks to a known metal. You really shouldnt have any issue machining unless its a very high carbon steel. You can weld higher carbon steel its just more prone to cracking.
bwringer
Indianapolis
What, you don't have a mass spectrometer in your kitchen next to the microwave?
If you want to know how it will machine and weld, experimentation might be the easiest, fastest way forward. Slice off a few chunks and, well, try machining and welding them.
MoonRise
Nah, x-ray fluorescence or XRF detector. :LOL:
From your pic, it -looks- like plain low carbon steel from the spark pattern. High carbon or alloy type steels with high(er) carbon usually show a forking/branching spark trail, but low carbon steel show more of a straight 'single' spark pattern and not multiple-branching spark trails.
W
WhoWhatNow
Collegeville, PA
Sounds like the answer is just get cutting.
Thanks guys, this put my mind at ease.
Although we do have mass specs at work….
Monza Harry
Windsor ON
Your first picture shows the finish of what appears to me to be CRS (cold rolled steel). Typically the same/similar composition as the CRS, just CRS is more crack prone (because of surface tension IIRC) while bending if insufficient heating is used for forming (intentional or not)! Harry
Sweetcorn
North Central Ohio
It certainly looks like cold rolled steel. There are quite a few steel compositions available in CRS form, but I'd be comfortable treating it as generic CRS until it reacted in some way when contrary to that when machining/welding.
It's not hot rolled, that has scale.
I'd treat it like CRS and carry on.
