Hi there, I've gotten a lot of great info and tips from this forum so thanks in advance! I have a question about electrical grounding. I'm wiring up a new workshop (and rewiring some old garage electrical that was overloading a circuit. Here are the basics:
1) have a 100 amp subpanel in garage.
2) ran 1 1/4" EMT conduit straight up into attic so that I can easily run Romex directly to the tools from the attic without conduit all over the walls and ceiling.
3) The 1 1/4" conduit from the panel terminates in a very large junction box (10x10 I think) in the attic so that I have plenty of room to work.
4) I'd like to try to run all my grounds for the various circuits to the attic junction box, then a single ground down to the panel to save space. Everything in that junction box is 12 gauge wire. I was going to run a single 8 gauge ground wire from the panel to the junction box, then tie in the 6 or so ground wires (12 gauge) for the various circuits to the main 8 gauge ground wire in the junction (none of these are the 240v tools, i ran those as completely separate circuits/conduit with 12/2 romex and individual grounds). Everything is also grounded to the individual boxes along the way, just looking for that last connection down to the panel.
5) Assuming that is ok... what is the best way to connect those? I was trying to find something like a Wago or other larger gauge splicing connector so that I'm not trying to hold 5-6 THHN solid 12 gauge wires against a stranded 8 gauge wire with just a wire nut. Or is a wire nut the best way?
Thanks in advance for any help!!!
Chris
Chris
