I'm not sure. But I do know Tekela makes my wife's cloths come off.oh...what flavor of alcohol worked best? ethyl meth isoprop?
Welcome to GJ, Scott
Congratulations! This is K60!
Let me be the first to give you the first "You ****" Great way to start your tool addiction on this board!!!
The drawer handles are not original, but you can slowly start acquiring handles from less valuable parts boxes from the period (if you decide to go original). May be somebody on this board has a couple of extras to have you started. Otherwise look up what's available online and see if there is something relatively similar to original ones (do not forget - they had 2 styles - earlier ones were different)
Again, CONGRATULATIONS!!!
P.S. Add your approximate location to your avatar
Earlier models had aluminum accent lines to the right and the left of the emblem. They also had bakelite handles.Thank you so much for the welcome and the information, Shelbylex! I would love to find the original handles and the name plate. If anyone has any leads, please let me know. What about the handle on the lid? Is that a replacement as well?
How can you tell if it's an early or later one? I've read threads on here that reference the catalogs, but they all look the same to me in the different year catalogs. Am i missing something?
I plan to give it a good cleaning at some point when I can figure out how to get the drawers out. I've read about the spring behind the rivet on the slide, but I'm not having any luck when I try to remove the drawers with a metal shim.
What kinda can conveyors had magnets? Mine were all aluminum, so I’m guessing foodstuff. Is this a newer innovation? I stopped reading Food and beverage related trade magazines 27+ years ago.a row of 1 X 2 X 5/16ths magnets (my source was old can conveyors
What can you tell me about the topper on the left? I believe it's the same model I have. Mine's missing the handle and badge on the front cover.Earlier models had aluminum accent lines to the right and the left of the emblem. They also had bakelite handles.
Later version had handles like on this K200.
Sorry for crappy bottom picture - can not find a better one of the current setup - reflections look like boxes are bent...
... Now you will need to look for one of those too : )
PBW for the win!My old KennedyKits 620 got a bath; found a home and a purpose!
Removing the old, mouse-infested felt was disgusting--but really hot water and some brewery detergent got it out with little elbow grease needed.
Some organization will be required, but that last corner of my workbench is now sorted--sort of.
Steel cans in canneries, but this was decades ago. multiple careers back. but we could take them down a row, hit a vertical belt and straight up, even had one taking them from the top and across. you just added more magnet depth for the load. when you wanted it to drop just stop adding magnets! (but have another magnet on landing so they don't bounce...)What kinda can conveyors had magnets? Mine were all aluminum, so I’m guessing foodstuff.
Close--we use Supreme. Pretty similar--a "mildly alkaline brewery detergent". If not used with some care, it will strip paint.PBW for the win!![]()
Yeah, I tend to forget that there are breweries that don't use chemicals from Five Star. I'm a bit biased toward their products. They are local to me, plus the rep has been very generous with sharing samples with me.Close--we use Supreme. Pretty similar--a "mildly alkaline brewery detergent". If not used with some care, it will strip paint.
I have sample tubs of PBW at home that I use for cleaning my coffee maker, mug and Thermos.
The one on the left is a slightly different model - it's 1963 KRA58B.What can you tell me about the topper on the left? I believe it's the same model I have. Mine's missing the handle and badge on the front cover.
As found:
Is there any source for things like the front cover handle and badge? I've started cleaning it up. Come good painting weather, I'd like to give it a full restore.
Thanks for the reply and info!The one on the left is a slightly different model - it's 1963 KRA58B.
The one you have is closer to KR-56 I have. It's 1955 and has different handles.
First 3 pictures are KRA-56, the last one is KRA58B
Your box has couple of differences - compartment layout as well as two vertical strips. Drawer handles are also slightly different.
Check at the sides and bottom for the stamp - Snap On would have a model and the manufacturing year. I am not sure if Canada made boxes back in the day - check for the stamp
I think you might have an MBC made tool chest (they made boxes for Snap On as well. MBC chests had a smaller rectangular storage on the right side and no strips on the front. Handles are consistent with MBC manufacturing.
I suspect it might be Vulcan - the layout of small rectangular compartment is on the left (https://www.garagejournal.com/forum/threads/vintage-vulcan-tool-box.461010/)/
It's unlikely to be Yorktown as they did not have
Source of the handle - try to see if there is an old big metal cabinet being thrown away somewhere - I think they had similar handles. If not, start looking for parts box or see if somebody is parting a box on e-bay or somewhere on the site. Same with the emblem.
(if its Snap On (less likely), it will be easier to find. If it's Vulcan - good luck!
Another thing against Snap On - hole shape on the left upper side - Snap On is 2 round holes...
P.S It would be interesting to see what other members will say - the vertical strips on front panel are pointing away from MBC manufacturing. But I also wonder if previous owner just added them...
PPS What do you want to make out of this box yourself? Very few people outside of this forum would really know the difference if you decide to restore it and put a different brand on it.
If you want to save this box and make it a Snap On: get a handle, the emblem and restore it. It's most likely made by MBC - which means that it's the same quality as any Snap On box from the time period.
GOOD LUCK!!!![]()
How is the quality?That should be a Waterloo. I think 90s thru early 2000s.
