test#5
Nighttrain
Dripping Springs, Tx
N
Nighttrain
This is killing me, I can post the picture with the insert image but it still stays small. I am using photobucket. There is no option under properties which allows me to change the size of the photo.
Horseshoe Jack
If you don't have a colon after http it won't work, and in the second case, if you have TWO http's it won't work ;)
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
In quick reply. As you post you will see the small logos.
7th along is insert image.
Click on that.
Click on allow pop up.
Click on insert image again.
Take out HTTP// as your properties have that.
Paste in the properties.
Click OK.
You image should appear in your post as
Now click submit to post.
