Motorman55
South Jersey
Painted the old oak cabinet I picked up last week. Decided to go with the same green color on the outside to match the new office's trim color. I'm leaving the inside unpainted you won't see it with the doors normally closed. Not sure if I want to mount it on the wall under the new office window or attach some tall wheels on the bottom to keep it mobile. Right now its just sitting on a HF dolley.
Magnum440d100
Indiana
Ashamed to admit that part of my clutter problem was pop cans in grocery bags in the middle of the floor, because I did not want to spend $20 to crush $10 worth of cans lmao.
Finally broke down, bought and mounted a can crusher. That’s white lithium grease I put on there, as it felt dry and like it was grinding.IMG_3369.jpeg
Turned about 10 grocery bags of varying fullness into about a half a 33gal garbage can. And yes those are the 24oz(?) monster cans. Part of my problem is chugging one, sometimes 2, of those a day! IMG_3370.jpeg
Indiana doesn’t have a redemption system as far as I can tell. But I can turn these in for a couple cents.
Basically beer money lmao
Glad to have some floor space back!
Now to organize the rest! (Later)
niget2002
Josephine, TX
Not in the shop 'yet'...
My 10yo son has been designing his own chess pieces by drawing them out on paper. Tonight we started the CAD work so that when we're done we can 3d print them. If he likes the way they come out, we may try to turn them on the lathe.
We had a lot going on this evening, so we got a late start. I just looked down and saw it was almost 9pm and he was still up. He should have been in bed 30 minutes ago! So we only got two pieces done tonight.
When it comes time to print them, I'll let him choose the two colors.
dchawk81
When I was 10 I was probably making mud pies.
Ultradog MN
Twin Cities
My shop isn't as tidy as some but it WAS reasonably well organized.
Wedneday I turned it into a total hell hole.
I bought some pallet racking for the other stall and am moving everything that was on these wooden shelves over there.
I'm reusing the plywood shelf boards on the pallet racks so EVERYTHING had to get moved - to anywhere and everywhere.
It will be a week or two long project that I was dreading but I got it started.
Craigslist has been my friend.
Have sold about a dozen items and have half a dozen ads there for stuff I don't need anymore.
niget2002
Josephine, TX
Yeah. I was still playing in the dirt at recess with hot wheels at that age too.
I'm doing most of the cad heavy lifting. I'm showing him witch buttons on the mouse do what. He's soaking it all in. By the time we get to the end, he'll probably be doing it. These are basic revolves. The knight is the only weird one because the head is flat on both sides.
GrayFlattop
Chicago
Looked for a utility knife that I can't find to save my life.
Ultimately ordered a new one on Amazon.
I've done that with utility knives, 12' tape measures and #2 Phillips screwdrivers (I really have well over a dozen of each, but if you can't find it, you may as well not have it). It happens when I'm in the middle of something and I get frustrated. Amazon, an iPad and after dinner couch time lead me into the lazy path. Once the replacement arrives, I will typically organize a bit and find even more of what I was looking for than I thought I had.
If, perhaps I have a had a cocktail or two, I just might order a dozen different #2 Phillips screwdrivers of different configurations...
I try to be responsible. Trolling through eBay while modestly buzzed can be a bad choice as well (to be fair, there are far WORSE choices). That is how I ended up with a factory case pack of 3 or 4 genuine Civil Defense Geiger counters for small money. Hey - I had a perfectly legitimate reason at the time...
I do believe (hope) such foolishness is behind be at this point in my life, although I need to continue with my organization and clean-up efforts.
dchawk81
I've done that with utility knives, 12' tape measures and #2 Phillips screwdrivers (I really have well over a dozen of each, but if you can't find it, you may as well not have it). It happens when I'm in the middle of something and I get frustrates. Amazon, an iPad and after dinner couch time lead me into the lazy path. Once the replacement arrives, I will typically organize a bit and find even more of what I was looking for than I thought I had.
I try to be responsible. Trolling through eBay while modestly buzzed can be a bad choice as well (to be fair, there are far WORSE choices). That is how I ended up with a factory case pack of genuine Civil Defense Geiger counters for small money. Hey - I had a perfectly legitimate reason at the time...
Indeed. I spent a couple hours looking for the knife yesterday because I wanted to break down some boxes. From Amazon of all places. So now I'll have to break down more Amazon boxes so I can break down Amazon boxes.
welder4956
Birmingham, AL USA
Opened the morning UPS deliveries - new body hammer and a 25 pack of 1/8" thick grinding wheels. Dang grinding wheels are getting expensive.
Then I worked on modifying the HF welder cart to make the gun angle better. I don't know why they think angling the gun upwards is OK. It puts a sharp bend in the liner that causes wire feeding problems with the 0.024" wire, not so bad with bigger wire. I also cut a piece of plastic brake cleaner straw to take up the gap between the drive rolls and gun liner inlet. The changes seem to have made a big improvement, zero issues with birdnesting in the wire feeder today.
