Beerhippie
I've been hand-tapping holes in steel, cast iron, stainless steel, aluminum, brass... the list goes on... for many years. I've always used "standard" plug taps. I'm sure you all know how that goes--half a turn, back off a half turn to "break the chip", make another half-turn, repeat until the tap clogs, back it out to blow the flutes clean--or just snap the tap off in the hole and start pulling out hair.
Well, I was doing my bored Youtube surfing thing the other night and watched a video of some guy ranting about how much better taper-tip taps were for hand-tapping than tapered or plug taps. Now, normally, I take this sort of thing with a pound of salt as so many videos like this are simple shilling for a product, but this guy seemed sincere and wasn't pushing any brand or product, just a style of tool.
I'd always thought that taper-tips were for machine tapping only.
So I laid about $8 on the line and ordered a two-flute taper-tip in 1/4"-20tpi, as that's my most-often used size. I've been using it for over a week now, mostly in steel and aluminum, and I'm sold.
In fact, my mind is somewhat blown! All these years, I've been beating my head against the wall 'cause NO ONE TOLD ME! This tap glides through metal when tapping a through-bored hole--no stopping to "break the chip", no need to clean the flutes.... The first time I tapped through over an inch of pure aluminum, I was convinced that I'd screwed up (again) and used a bit that was too large for the hole. Nope. It was right. The chips all were falling out the bottom of the hole and there was no clogging of the flutes at all.
Now I need an entire set from #6 to 1/2", NF and NC, plus metrics in the same range. That's gonna get expensive. Maybe I can sell my plug-taps to some sucker?
You all probably know all about this already, but I thought maybe there might be one person who doesn't--like me.
