REFLEXX
Here's a wierd one.
I have a milling machine (aka knee mill, Bridgeport, etc..)with a 3ph Variable Frequency Drive (VFD) motor in my shop. It's wired 220v single phase on a dedicated line. Works fine, no issues with power.
Bought three LG room air conditioners (for three rooms). Finally got the A/C that is in the same room as the mill into the hole in the wall. It was getting hot in these parts. Plugged it into it's own 115v dedicated circuit. Works great, quite, blows nice and cold. The plug has a AFCI built into it. It's the size of a ******* bar and has the typical TEST/RESET buttons.
The next day I go to use my mill and turn on the spindle (the VFD motor) and the AFCI plug pops instantly. DAMN IT! I instantly assumed that I wire something wrong. Tried it again, same result: reset AFCI, turn on machine, AFCI pops.
It's on a separate circuit!
So I'm thinking that I'm a *****. Maybe my mother-in-law was right (imagine a New Yorker accent) "certain things you should leave to professionals"
A HA! I've got another A/C unit (same make) on a rolling cart. So I wheel it over to another (isolated circuit) outlet. POP! same result. Another outlet, POP again.
Now I know it's not my wiring, but I'm lost
I get on line and dig up what an AFCI is:
AFCI = arc fault, circuit interrupt. if there's an arc in you old, chafed, crappy wiring, this will keep it from throwing big sparks and starting a fire.
BUT! every time a switch is turned on, you generate a tiny arc! On this cord, I've got an "ARC SHIELD" AFCI plug made by Texas Insturments. I learn that this "patented" gizmo "can tell" the difference between a switch arc and an arc fault. I also learned that a few years ago, the government (to protect us from ourselves) made it a rule that all room A/Cs have one of these AFCIs. My guess is that too many old mobile homes got burned up when a "high amp draw" A/C cooked the wiring. But that doesn't help me. I've got oversized wiring, all 20amp for this A/C that plugs into a 15 amp receptacle.
I called LG service and they don't answer the phones. I called TI (now called Sensata or something) and no answers.
Right on the plug it says, do not remove and do not cut off. So I cut it off.
I installed a 20amp GFCI recptacle, wired on a heavy duty (20amp, 3 prong) plug and plugged it in. Turned it on, no problems, blows nice and cool. Then I truned on my machine. VIOLA! No effect on the A/C unit. No dip in voltage, no dive in the A/C fans, no big sparks. Seems to be running just fine. I've turned my machine on and off a hundred times today with no ill effects (so far).
Why did I post this? Because I want your opinions and to give you my theory and to see if others have had the same experience. I think this AFCI is too sensitive to exist in a "shop/garage" environment. All our tools, machines, and motors have switches on them that make "arcs" that this gizmo is fooled into thinking that it's a bad.
So I'm the guinea pig. I'm thinking that the GFCI will protect me and the A/C unit, just like any other electrical device. Am I wrong?
It's on a separate circuit!So I'm thinking that I'm a *****. Maybe my mother-in-law was right (imagine a New Yorker accent) "certain things you should leave to professionals"
