I have been in this place since 1991. I replaced a bunch of sheet rock from water damage a many years back, but as far as damage from hitting the wall with something, it has been almost nothing. About every ten years I toss on a coat of paint. I might patch a couple divots before the point goes up, but I don't remember any serious damage.No maintenance is laughable. Drywall in a garage is going to be full of dings and gouges in a year or two.
This is what I did. Painted it. It's good enough for a shop and makes it way easier to hang things up.Went w/ OSB back in 96. Texture sprayed it to hide the ugly. Looks good still & I can fasten anything anywhere.
Eh, I don't know what your work habits are, but I'm glad that I gave you a laugh.No maintenance is laughable. Drywall in a garage is going to be full of dings and gouges in a year or two.
Wow. Yeah, shipping is a thing for your location. 5/8" is $10.88 at local big box stores near me.5/8" is almost $30 a sheet
Lean shovels, pipes, boards, sheets of metal, ladders against the wall. It just eats into drywall in a short time.I have been in this place since 1991. I replaced a bunch of sheet rock from water damage a many years back, but as far as damage from hitting the wall with something, it has been almost nothing. About every ten years I toss on a coat of paint. I might patch a couple divots before the point goes up, but I don't remember any serious damage.
What are you doing that you have heavy objects flying around, out of control in your shop?
Plus with drywall a repair is a few dollars in mud and you don't have to replace a whole sheet.
Perhaps I am a bit more careful.My question is what are you doing that never damages drywall? Sitting drinking coffee? Even tin and plywood get scratched and paint worn off in some areas in most shops I've been in.
I have a few different samples of EZ Liner, EPI (Extrutech Plastics, Inc) and the Trusscore and really like the ease of the install and not worrying about expansion cracks in a large section of drywall. The finished drywall costs are almost of the same as material costs with PVC panels. EZ Liner looks like you can get it at Tractor Supply and HD, but in short 8' lengths and 5 packs and not cheap. Same with Trusscore on the HD prices. Anyone have a good distributor source on PVC panels?
I'll stick with my rough sawn pine. Under $20/4x8 ,(.60/bf), easy to handle and install, no finishing required, looks good, and even smells good.
Not a fan of drywall in a garage/shop (I prefer R-panel / liner panel), but every time this statement comes up, I question how/why folks are beating the heck out of their walls. I've used the heck out of my buildings for decades, and I can't think of a time where I've damaged a wall.
That came out very nice. How heavy are those panels compared to drywall? Can one guy handle a full sheet?I recently finished my garage with LP Smartside panels.
my thoughts exactly. Can't remember ever damaging a wall or really even hitting a wallNot a fan of drywall in a garage/shop (I prefer R-panel / liner panel), but every time this statement comes up, I question how/why folks are beating the heck out of their walls. I've used the heck out of my buildings for decades, and I can't think of a time where I've damaged a wall.
I buy it from the Amish - probably 10 or 15 communities within 20 miles that saw lumber. I guess it that is not available to you. I like the 1" thick solid lumber over 7/26" or 11/16" OSB. I think it has a lot more holding power and spans further, plus looks better, no finish required.Last time I bought rough sawn pine from a lumberyard it was more than twice that cost....
I think it’s likely a factor of size. My garage is 20’x25’ and I keep two cars in there. Keeping clear of the automobiles means that things will bump and rub against the walls as I move around.Perhaps I am a bit more careful.
I used to all kinds of auto repair, tunes ups, oil changes, brakes, engine rebuilds,(I sound like Mona Lisa Vito!). I have built a couple trailers, weld, grind. Service and repair my motorcycles, wood working, body work, I have painted a couple cars. I just repainted a small trailer I pull behind my Goldwing.
It is a home shop so it isn't like it gets 8 hours a day use. But years ago I worked out there pretty much every weekend and 2-3 nights a week to help make ends meet. I am retired, but I probably spend 20 hours a week out there.
I don't sit out there and drink coffee or beer. I have a deck or family room that is much more comfortable. I never have understood the sit around the shop and drink when there is more comfortable places to relax.
I did my garage with 5/8 drywall for fire safety as I weld, grind etc. yes the walls are getting dingy, but the semi gloss white really helps my eyes see with all the led lights I put in. As soon as I get my 50 chevy truck done to the point I can pull it out I will clean the walls, maybe put another coat of paint on the walls if I feel they need it.Cutting, welding, grinding, exhaust soot... It all adds up and walls get dirty.
I am comparing labor costs exactly because this is a DIY site. I was able to finish my walls by myself with about 50 bucks worth of caulk and sanding belts. If I had used drywall I would never attempt to finish 1600 square feet of drywall by myself and expect it to look even half assed decent. What do you reckon professionally finishing 1600 s.f. worth of drywall seams would cost? I'll bet it is more than the 50 bucks and a few hours I spent. And it looks really good. Do I want it in the living room? No. But this is a working shop.Why are you comparing the “labor cost” of drywall but ignore it on the OSB you installed? Especially on a forum that is mainly DIY?
Bring up the cost of cheap drywall tools and tape/mud but ignore the belt sander and caulk you used on OSB?
And OSB absorbs much more paint than drywall does!
My buddy just sheeted the ceiling of his garage with drywall. Finishing tool was a $10 caulking gun that he had already, and typical painting tools. He caulked the seams and painted. I think it looks fine for what it is. It is a garage, not some palace.If I had used drywall I would never attempt to finish 1600 square feet of drywall by myself and expect it to look even half assed decent.
I think this just comes down to what kind of person you are. Some people can do a complete rebuild of a tractor in the middle of a muddy farmyard in their best Sunday clothes and not get a speck of dirt on them. While others merely have to look at a vehicle and they are covered in dirt, grease all over their hands, rips all over their clothes, and blood coming from at least half a dozen places.
Is texturing drywall a regional thing? I've only seen it in commercial settings and in 55+ condos in Fl.
I may be ridiculously slow at mudding and taping, but seriously, why texturing as DIY? To hide a bad job? Seems like it makes the walls hard to clean, especially for a shop.
I had a small engine shop. All the walls were sheet rock. Beings it was a commercial space I tried to keep it clean and fresh looking. Every winter I had some slow months. The more pubic areas got a coat of paint. In five years the warehouse area never got a repaint and the walls were fine, other than a bit dirty.Yup...drywall is for garages (parking cars), tougher materials are for shops (working in).
All I've ever had were open walls with exposed studs. Lots of extra storage potential in the walls. But of course, no insulation.
If I had to enclose my shop, it would be metal over OSB. I do a lot of welding and metal cutting which is the reason for metal, and the OSB under it means you can drill & screw anything to it anywhere on the wall.
I don't concern myself about my sheet rock walls and do all you mention.For me anyways, I just don't want to have to constantly think about the walls. I'm a bit OCD, so I could keep a drywalled shop spotless if I wanted to...but I don't want that on my mind when I'm out there. I don't want to watch where the jack handle is when lining it up under the vehicle. I don't want to lay my digging bar down on the floor....I wanna lean it up in the corner. I want to shove my jack and jackstands against the wall and out of the way. My stepladder...just prop it up against the wall anywhere...
Stuff like that.
I find it funny that you have an opinion on which is better, but you have not had experience with either!
Oh...so you know all about my history do ya? Or is this a touchy subject?
I have had experience working in many garages. Drywall, metal, T111, and block.
I just said my personal garage is open.
