Let's Talk About Miter Saws
karoc
Hemphill Tx
Know nothing about that saw since never owned or used one. But if you break that setup down into stand and miter saw then check price of two components it’s a heck of deal. Myself I have Dewalt and Makita non slider, but I want a slider 😩
mike93lx
Richmond, VA
I have that saw on a similar stand
I like it, but it's huge and heavy. After owning a 12" slider for a while, I don't think I would do the same again. A 10" slider has almost all the capacity but is a good amount lighter
Smiles79
Northwest Missouri
Does that saw seem accurate?
txvwnut
Bedford, Texas
That looks to be a smoking deal as long as the saw hasn't been abused. I paid more than that for my Dewalt miter saw ten years ago.
Augus7us
Central Ohio
That is a nice saw for the price, the stand is a bonus and probably costs 200 new. Agree on the heavy comments but rolling it out on the stand will make that easy.
The nice thing about this and the Hitachi's is that they use an articulated arm instead of slide tubes. This means you don't need the 6 or 8" of clearance behind the saw like my rigid and many others.
mike93lx
Richmond, VA
A great feature when it's built into a bench against the wall, but much less useful in a portable arrangement.
@Smiles79 if you grab it, I find storage is much easier with the saw rotated all the way to the right. It cuts the depth a good amount
whateg01
doo dah, kansas, usa
That HPT uses slides, but it places them Forward instead of poking out the back. It's not like a Bosch.
Augus7us
Central Ohio
Yeah I googled metabo and ended up looking at a hitachi. Seems most are moving to some type of articulated arm or forward facing tubes. Even the Hercules...
If you want portability don't buy a 12" sliding mitre saw, I have a non sliding 10" ryobi I can carry in one had and will cut most stuff for diy around the house. A new 10" ryobi is under 200 new.
mike93lx
Richmond, VA
Metabo and Hitachi are one in the same
Augus7us
Central Ohio
Hitachi owns Metabo, that doesn't make them the same saw. You're welcome to go look at pictures of both saws if you like. What does this have to do with the OP's question again?
mike93lx
Richmond, VA
Because that same saw was branded as a hitachi. Like the one in my garage
engineer2
Chicago burbs
Menards has a $449 Metabo saw that looks just like it on sale for $266.
I'd say it's a good deal with the stand especially if the blade is sharp.
tarbellb
Oregon
One of the best miter saws on the market, period.
Festool copied them, that says something
That saw and stand are a excellent combo and a smoking deal
Run and throw money at them
MushCreek
Upstate South Carolina
On a good stand, a 12" saw isn't too much. I have a 12" Ridgid slider on the Ridgid stand, and I can set it up or break it down in 30 seconds. It has 12" wheels, which are great on rough ground. When storing mine, I rotate it 60 degrees to the right to make it as small as possible.
What the OP posted looks like a good deal to me.
seber
Deep East Tx.
I've been using a Hitachi for 20 years. Still works like new. I think Metabo and Hitachi have always been the best bang for buck power tools on the market.
Retroman
Mojave Desert
Bought a Dewalt 12" slider less than a year ago not real happy with it.
Just bought a used Hitachi C 8FB 8" slider made in Japan. It had been neglected barely slid or beveled so spent few hours cleaning her up put $40 worth of parts into and got a fantastic lightweight slider for $100. So the Dewalt will probably be going up for sale.
Yes I think that 10" is a good deal at that price with the stand.
wandrur
Fredericksburg, VA
Great deal as long as it hasn’t been left out in the rain
Looks like a great deal, ask if you can make a few cuts and then you'll know if it's ok.
Agreed with everything above here.
I bought a 12" DeWalt (non-slider) in October 2022 on sale for $300.
I say you throw down the cash and walk away happy. Seems like a great deal, provided there are no issues.
IRQVET
Forgotten Coast (FL)
I just retired my Evolution Rage 10 compound miter saw and upgraded to a 12 inch Dewalt 779. I think I need to ditch the stock blade, but I'm not 100% sure which blade and tooth count I should go with?
I just upgraded my table saw to a Diablo Combination 50 tooth blade. But not sure what to do about the new miter saw?
jar944
Northern VA
What are you cutting?
That will generally dictate the blade type and tooth count.
IRQVET
Just starting out in wood working, so I have no clue. I know with my table saw someone suggested using a combination blade around 50 tooth count, wasn't sure if a miter saw had a similar recommendation- like a well rounded blade that does everything pretty good, but not to a higher finish level of a pro?
jar944
Northern VA
It's hard to recommend a generic do all blade. Cutting construction lumber and trim requires different blades. You can do use one blade for everything but it won't be good at anything.
Digital Ranger
Cambridge
10 inch basic Dewalt has been wonderful for our house build. I put it on a Rigid stand and it's been a good combo for us. If you can score both on a sale, nothing wrong with it.
tarmy
Nor Cal
Miter saws use a thin kerf blade…get a good quality carbide tipped 60-80 tooth blade. Good blades can be sharpened and with last a long time.
Read up about blades for the various uses/wood types. Radial arm saws use a reverse hook design for example. Starting out get the best decent blade you can afford….and figure things out from there.
I use Oldhams and CMT carbide blades
seber
Deep East Tx.
Miter saws do not need combination blades. They only do cross cuts. As Tarmy said, 60 or 80 tooth. Quality will be determined by the type of work you do. Cabinetry is a lot different than carpentry.
IRQVET
Been looking at CMT or Diablo. Tooth count is was kinda hanging me up, not at the skill level where I'd be attacking finished carpentry. I'm just starting out in woodworking.
whateg01
You haven't seen me put a 75 degree miter on the end of a 2x4!
jar944
Northern VA
There is no reason to use a thin kerf blade on a miter saw, there isn't a power advantage using a thin kerf instead of a full kerf. The advantage of full kerf blades is they deflect less.
tarbellb
Oregon
Although I would not recommend the Kapex, not sure where you came up with that?
When looking at the main difference in how these saws operate- the fixed rail that protrudes towards the user
They copied the Hitachi C12RHS which came out before the Kapex.
jar944
Northern VA
That overall form factor has been around for 30+ years.
What design do you believe originated with Hitachi.
Dakotadadv8
2002 Dewalt corded from HD buy good blades and right blade for the material you are cutting. Multiple DIY renovation projects over 20 years. Amazing it costs $275 new back then I would assume it would costs at least $500 now.
tarbellb
Oregon
I haven't seen that form factor on a consumer grade saw before the Hitachi
Wouldn't be surprised if a different mfg brought this to market first? I just have only seen the Hitachi
What I was pointing was that Kapex/Festool fan boys may think it was a novel idea, but in fact the Hitachi executed this design very well , for (much) less money, and before Festool
LOW1
ontario
Bring a speed square and some wood scraps and confirm that it actually cuts at 90 and 45 degrees.
Unless it’s been in a flood, dropped from a roof or stolen it’s hard to go wrong at that price.
SwissMetric
Switzerland
The miter saw of the 1st post must be a Hitachi (maybe sold as Metabo in some markets???), all Metabo miter saws I know look different than the one pictured and are typically dark green with some grey metallic aluminium diecast parts. The Metabo I know are quite reliable, excepted the laser. Here referring to the European models as I'm in Switzerland.
Some power tools are obviously only availabe in some regions and also the voltage is different in the U.S. Didn't notice many changes since Hitachi acquired Metabo and I don't know Hitachi power tools well enough to comment them, formerly they were light green but they're not very common here though already sold in the 90's.
