Good and proper C clamps
ChiefBeef
New Jersey
Howdy fellas,
I'm looking for some C clamps that can actually stand up to hard work. I am so tired of using HF clamps and the second I start reefing on them, they pretzel up or I flare out the pad and soon as it comes off, only thing that's left is the dingus end floating in the breeze.
Enlightenment is greatly appreciated.
matt_i
SE Michigan
I have a few sizes of Wilton 400 series in pairs and they seem to perform well for general purpose work.
zkling
Kant twist, and F clamps. Bridge clamps if you must C clamps.
danielbuck
What's the trick for getting tons of pressure on an F-clamp? It looks like they all have rubberized handles and so forth.
those are probably the wood clamps. the metal working clamps are all metal, like this, and also in a few different configurations:
https://www.amazon.com/dp/B07G2WSMPV/?tag=atomicindus08-20
They don't really look like they will hold a lot because of the sliding arm, but they will.
If I were you, I'd get 2 of this style f-clamp, and two Kant-twist clamps in whatever size you normally use, and see which you like best. I have a variety of sizes of both F and Kant, and can't really say which I like better. sometimes one works better than the other depending on the situation. Can't have too many clamps ;-)
Steve_P
Williams forged c-clamps are great and made in USA. not cheap, but a fair price for the quality and USA made
C
ChiefBeef
New Jersey
That's a good idea, and no you can't. Could have used a few more sturdy ones today, trying to guide a spindle back into a strut!
dr_clyde
Holland, MI
I buy Wilton clamps if I can for new. Used, old Hargrave Armstrong, Williams and Grand Tank are my preferred clamps.
We use mostly sliding bar clamps or “F” clamps for general clamping, but sometimes you gotta have a C-clamp.
The Wood use F clamps have wimpy handles so you can’t over torque the handles and ruin the clamp. I’ve seen people tighten then with pliers, and they slipped ever after.
I buy lots of C clamps used.
dr_clyde
Holland, MI
FWIW, there is a HUGE difference between woodworking “F” clamps and ones designed for metal.
Stronghand, Wilton and Bessey makes good ones.
Indexmill
Central NC
This right here is the correct answer. Buy old USA clamps that aren't fucked and restore them.
seanb02
The Farm
I purchased 2 sets of these ones last year:
https://www.amazon.com/gp/product/B01CVKL1B8/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
I like them a lot for clamping things to the table for welding and whatnot. They hold extremely well, and feel very solid when applying a lot of pressure. I'll likely get another couple sets of them in the near future so as to have 4 total of each size. Originally thought I would just get the two sets and see how the quality was then just buy a couple more individuals in the larger sizes, but I find the smaller ones to be quite useful as well.
Jason280
Go to your local pawn shops, and buy all the USA manufactured clamps you can find.
C
ChiefBeef
New Jersey
Curiously, as far as old clamps go, my best & most reliable one is made "SRI INDIA" (presumably built in Sri Lanka?)
Never seen another like it, but I've given that thing a beating and it refuses to quit.
Joebass
Ny
For C clamps, look on Ebay for older Wilton 400s. I like Besseys or Strong hand f clamps.
tarbellb
Oregon
Compared to HF clamps, most will be a upgrade.
Bessey still makes some high quality F clamps, be sure to look for the German made options. Same with older Jorgenson, Wilton.
And like others have mentioned, a wood clamp is not a metal clamp, clamps are where the boys get separated from the men.
MushCreek
Upstate South Carolina
I have nearly every size of Kantwist, from 3/4" up to 12". I used them as a toolmaker, and they're great, but expensive. I also have a couple of 24" Bessey F-clamps. Also good; also expensive.
N8sToolz
Reviving an old thread.
I just picked up an entire lot of 50 C clamps. Nearly all USA from the before times. Williams, Bessey, Wilton, Jorgeson, Craftsman and others. Ill never have to buy a clamp again.
In the lot was about a dozen of the clamps labeled SRI- India. They appear to be rugged as hell heavy and thick threads. Just trying to see if there was any more info on them. If that was the COO or the name of manufacturer.
