theoldwizard1
... knowing you will probably never use them again ! And your grandkids will be asking "What's this ?" when you are gone.
- Small flat head engine (Briggs & Stratton) valve spring compressor. (I am not "talented" enough to do it with common tools). Believe it or not, the engine had a stuck valve. Remove, clean the valve stem and the valve guide, reassemble. 50+ years messing with small engines and I never needed one until last year.
- Briggs & Stratton flat head starter clutch removal tool (funny looking big socket). Giant arc joint pliers didn't work. Could not get a big pipe wrench on it. The "right tool" and the giant HF 1/2" breaker, made it easy. (Rope in cylinder to lock the piston in place.) Clean. Apply Fluid Film. Reassemble.
