Hooked
League City, Texas
Not today, but a few days ago. Replaced the front warped rotors on one daughters Expedition. Also replaced the drivers door window regulator & motor on other daughters older (2007) Expedition when window wouldn't go up. Grandson is driving it following wreck in his RAM truck. Turned out the regulator/motor wasn't the problem but rather the switch for that window. Learned how to easily test those switches in the process so not to upset about the extra work/$$$.
CoogarXR
Set up a new wifi access point. I have been putting it off for a while, since I knew updating my wifi would murder my printer. My printer has ethernet, but it runs on an old-*** wifi bridge that only supports WEP, and nothing newer. I always ran WEP, because I live far enough from everybody that it doesn't much matter. But my new access point won't go full speed if I enable WEP, so I went to WPA2. Now, I've got no printer, lol.
I ordered a new bridge for the printer. Sure, I could run a CAT5 drop to it, but I might be moving soon, and crawling through the attic for a cable drop doesn't seem like a good use of my time.
But yeah, I woke up this morning to 0.18mbps on the speed test over wifi, and the usual 100+ on the wired, so the ol' wifi access point had fizzled itself out. Luckily I had one in the garage that I already bought a while back.
Jim_No_Garage
Millington NJ
So after several weeks of avoiding the situation I test fired the vintage audio amplifier that I swapped out all of the capacitors and rectifiers on.
I got some sizzle and some smoke at 80V thru the variac and shut it down. I was a bit bummed to say the least. After doing some sniff checking I wasn't sure what was happening so I went into diagnostic mode. All of the good bits are on the bottom so I needed to flip it over to see what's going on.
I clipped the RED wire from the rectifier output before the filter caps and started testing the AC to DC process. I'm getting arcing at the DC (-) connects and the DC(+) pin that is next door on the terminal strip. I need to look at everything there and see what's happening there.
Cheers
Jim
Fixr
SW VA
Cheers
Jim
Have you checked the gonkulator armature?
Old Man Roger
Palm Coast Florida
Reassembled the top shelf and new bottle rack on the modified HF welder cart. I didn't like how low the original safety chains were positioned to hold the gas bottle in place, so I made a taller rack. Then changed the oil and filter on the Cub Cadet, blew out the air filter and gave it a wash.
You don’t want the bottom of that bottle popping out over a bump or something. Maybe a second chain down low?
isb cornbinder
Ouch! Double ouch actually...
What happened to need to start over like that?
I started to pass out and I fell and could not get up. There was no feeling below my waist. The ambulance took me to the hospital. I was in ICU for the next 6 weeks. I had an infection called sepsis. I lost some eyesight. hearing and much of my balance. The nurses dressed in Haz Mat protection when dealing with me.
After I got home I had home visits from the City Health Nurse, daily. She took blood samples.
I broke out in hockey puck sized open sores on my lower left leg. I was an outpatient for months, 3 times a week. The sepsis had returned. I had intervenes at the hospital for two weeks. I am doing OK, now.
I was circling the drain for a time. I am not afraid.
There are some other minor issues, I am dealing with them.
Fixr
SW VA
50K lbs of stolen snowplow. After a long sleep and thousands of seizures, I got to start over. My doc said, "Welcome to 70, kid.". In another convo, "You'll be lucky to make it to 30.".
OK, without delivering a reasonably full story including who did what to whom, that kind of teasing is unkind.
But you might have a future as a writer.
Fixr
SW VA
I'm gonna say that you are some kind of tough. Everything I've heard about sepsis is really scary.
But, I've gotta ask - did you ignore warning signs?
big bab bob
Sydney
My thoughts are with you, cancer patient here, I have a small understanding of your plight, everyday can be a struggle. Hang in there and keep swinging
isb cornbinder
I did not notice any warning signs. My left lower leg was a little numb, now and then, but that could have been an old age thing. I learned a few things.
In the 6 weeks I was in the ICU, I lost 6 persons I knew, to sepsis. I was told sepsis can move quickly.
Fixr
SW VA
Damn. That is really scary. I thought maybe you were one of those "tough guys" who would never go to a doctor because it might hurt their reputation. I'm glad you are still here.
nadogail
Coronado, CA
After I was forced into Retirement I began working on a project that I wanted to do since I was 12. I am now declining to begin projects that I know that I won’t finish. I think I drew my last job related paycheck in 2006.
I still do jobs for my rentals, but I would not hire me because I take too long to get things done.
For Example I have been building a 48” wide gate all week. In my prime I could throw a few of them together in an Afternoon.
nadogail
Coronado, CA
Mrs. Nadogail and I had our checkup with our Physician.
We are both in “Acceptable” health. Dr seemed to be impressed that I am building a gate at 84.
I told him I can do things because I have power tools.
I told him I am planning on celebrating my 85th Birthday soon. He will be 80 in a couple of months.
Dr is a Veteran, he was drafted in 1972, when his Student Deferment ran out because he graduated from Medical School and had started his Residency.
56vette461
Retirement is so much better than some say. I'm at 23 years 3 months from a 30-year full time career. Many of my friends retired to sit in their chairs and wait. Others traveled full time up into their mid 70's. I enjoyed working some at other jobs, volunteer in the community and then traveling with my bride of 50+ years. Retirement is all you make of it if you are able to stay healthy and active. Projects are finished if I still like them, or tossed if I don't. Make the best of those years you have in retirement, we work to hard to get here.
kbeefy
Harington, Eastern Washington
Time for some Visual Progress....
Measured twice, marked out some cut lines, and went to town. Used Electric shears for most of the work, cutoff wheel on a grinder for cutting the roof cross ribs and channels.
I used some bumper jacks and magnets to support the roof during the final cuts.
And just like that, giant sunroof!
I lost my helper at this point, so I had to get creative moving the top around.
First I had to get it off my utility trailer. My 2 post lift worked fine for that, but then was about 1, too short to get it onto the van.
I wanted to try and use my Gantry to lift it, but had to get it off the 2 post to do so.
A transmission jack, hydraulic lift table and some sketchy cribbing did it.
After about 25 adjustments, I was able to lift the top sorta level. It was still barely enough to clear the roof, I had to drop the rear van tires down to 7psi for a couple extra inches of clearance. My Gantry frame will still go 1' higher, I will make that adjustment if I need to remove the roof.
I tried using the bumper jacks again, but they didn't work very well. I have to lift on the frame, and it is outside of the roof cutout.
With all of the extensions on one set of arms, I was able to lift high enough to get some of the cribbing out, one end at a time.
Almost down...
Last thing I did last night was to build these corner lift points that should allow me to drop the top all the way to the roof to determine what else needs to be done.
I figure the top will probably be raised/lowered at least 10 times in the next few days to figure out how to make this 3rd gen top fit my 4th gen van.
Jgaz
Almost down...
Nicely done!
Improvise, adapt, and overcome
