Let's See Your Vintage Electronic Testing Equipment
Mike'smeatshop
A few weeks ago, I won a Biddle megger at an auction.
Output voltage is a little over 500 volts. Shows the correct reading testing a 1 megohm resistor.
Hope to find a copy of an original owners manual.
EDIT: Just found that it was probably manufactured in the late 1970s.
Great find. What is the blue handle for?
Mike'smeatshop
Yep. Hair checks out for late '70s-early '80s!
Here's my only "vintage" meter I have around the shop:
Sperry Instruments "Snap 6" AC Volt, Amp and Ohmmeter. I don't have the leads, which screw into the back. We used this for years for diagnosing pump motors around the brewery, mostly as a clamp-on ammeter. It was superseded by a Fluke 112 and various kit for it.
I wonder how far back in history till the amp probe got used?
humber2
Downunder
Google 70143 megger manual
Or
Wm6 megger manual
For more information, WM6 is an updated version with 200 megohm scale, very little difference otherwise.
Beerhippie
Far NE Oregon
Amp probe is the inductive clamp. We used it a lot back when. PITA when working on a 3-phase motor and comparing the three windings, as you have to separate the three feeds in the little connection box to fit that big clamp around each one.
I don't think the leads would be used for Amps, unless an external ballast was used.
Mike'smeatshop
Ya but you got to have one on single phase motors. HVAC.
WildBill
PNW
I got a bunch of these from a local college, the date is when they were last calibrated. They sat in a locked lab cabinet for 35 years or so. Nobody knew who locked it, where the key was, or what was in it. Bought a whole box of misc ones for $25, mostly these two models. Somebody was smart enough to pull the batteries, which was awesome.
Mark in Indiana
Southern Indiana
The rotating meter head was a nice feature. Kept the readout in sight without holding the meter.
Mike'smeatshop
The Sperry was a nice amp clamp meter in its day.
I used an AMP PROBE RS3, but I would have used the Sperry if I could have afforded it.
What years did you use those? I used Fluke for years and they did me well. Starting in 1990s.
Beerhippie
Far NE Oregon
We used the Sperry back in the '90s and '00s, until we hired an employee whose father was a high-mucky-muck with Fluke. He gave us several multi-meters and accessories--including an inductive Amp clamp. The Sperry became a wall-hanger after that. It's hanging on the wall right next to my desk right now. I still use the Sperry occasionally, as the clamp is smaller than the Fluke and fits tighter spaces.
tool_scrounge
Southern California
Fluke 515A portable calibrator, 1970s vintage
From https://www.radiomuseum.org
“The Fluke Model 515A enables the field checking and/or calibration of the dc voltage, ac voltage and resistance ranges of high accuracy voltmeters and multimeters. The model 515A provides standards for dc voltage, ac voltage and resistance which maintain the basic accuracy over the temperature range of 23°C +/- 5°C. Self contained NiCa batteries permit operation at sites remote from ac power, and also permit operating temperature of the unit to be maintained while in transit. Up to eight hours of battery operation is available from a single charge.
DC voltage outputs are selectable in the ranges of 0-999 microvolts(continuous),100 millivolts to 1 volt in 100 mV steps,1V to 10 V in 1 volt steps, and 100 V.
AC voltages are selectable 1,10 and 100 Vrms at 400Hz,10Vrms at 4kHz,and 10Vrms at 50kHz.
Resistance is selectable at zero,10,100,1K,10K,100K,1M and 10 Mohms. All pushbutton selection switches are mechanically interlocked so that only a single function can be selected.”
I have tested a lot of older and current Fluke meters with the calibrator. All the Fluke meters were well within specification when compared to the calibrator. I was surprised on how closely they all matched.
img_0268-jpeg.2084772
Mike'smeatshop
That is a gem. That is something the Ky Public Service Commision would have here in Ky. Very cool.
Beerhippie
Far NE Oregon
Anyone interested in this?
The cabinet is locked with no key, so no idea what's inside. The place it's at is asking $50, but it's been there for a decade or so and the new owners are trying to move some of the stock. I'll bet it would walk for half or less.
If anyone's interested, let me know.
Mark in Indiana
Southern Indiana
I’d have to pick the lock to see what’s inside. Even though it might be Capone’s vault.
Blue Chips
Maine
I just saw this thread.
This General Electric Company "Thomson Indicating Wattmeter, No. 14721" might be the oldest test instrument in my stable, with a patent date of February 11, 1896. It states: "Potential Limit 150 Volts" and "Current Limit 2 Amps." The two pairs of terminal posts are labeled "P" and "N." I haven't tried it, and I probably won't, but I suspect it still works. The needle movement is still smooth and free.
Here’s my contribution…too spooky to test with.IMG_6301.jpegIMG_6297.jpegIMG_6298.jpegIMG_6299.jpegIMG_6300.jpeg
When I first started working in my Father's shop he bought an Allen set on a rack that had casters. It included the meter shown with ammeter and voltmeter. The other half of the set had a cam angle meter and a tachometer. I wish I still had them as times. When he retired and I went to Alaska for a few years he took half of the equipment and I took half. I still have most of my half, but some members of my family who weren't friends took his equipment when he passed away. By the time I returned to the lower 48 nothing was left and no one knew anything!
That is life!
bctexas
Aubrey, TX
Yer killin me. If that wasn't 2000 miles away I would add that to the collection in an instant..... *sigh*
Beerhippie
Far NE Oregon
Road trip!
I once did Big Bend TX to Portland OR in two 1,100-mile days on a bike. My *** hurts just thinking about it. Still better than the three days on the way down in a '48 Willy's PU at 45 mph....
johnre
Portland, OR
I guess 26 years old makes it an antique, but still, it doesn't seem to be that old:
The price was right - I'm a long term employee, and we have a great surplus equipment store. Came with the front protective cover; I've got eyes out for some P6139 probes; these will get the full 500 MHz this thing is capable of. No batteries, but I could make a set: I wouldn't do the NiCd it came with originally.
And it's the original TDS 3054 model, so no flash drive on it. But it has a serial communications / GPIB adapter, as well as a 3.5" floppy drive - and I still have a USB device to 3.5" floppy adapter and some spare floppies, so I have two ways to offload waveforms!
Ayrhead
Ontario
And a couple more…
I recently pickup up some more old testers from a gentleman’s grandfathers personal collection. These were used by him back in the day…
Ayrhead
Ontario
The remaining pictures of his meters. They seemed to have been taken care very well as the dates on the dual meter are in the late 1880’s and early 1890’s…
