Wrench97
Southeastern Pa
Installed a CP4 disaster kit by S&S diesel. While taking my manifold plenum off I noticed a coolant leak from the radiator hose coming off the main core and going to the top of the block. It was also leaking on the down spout as well. Replaced with OEM 180 bucks... I wasnt expecting it to be that much.
You can buy and change the o rings in that hose end quick connect.
kaymccampbell
Upstate New York
Went to Restore to drop off some stuff and found this old Craftsman scroll saw for $40 so it came home with me. Of course I needed a place to put it so I dug into the scrap pile and put together a little table for it.
Still need to sand and paint the table
I have that one's older sibling. It was about $40, 40 years ago.
PWC Repair
Arkansas
I spent a bit over 4 hours with a block and 180 grit roughing in the bottom of this old Kawasaki 550 stand up ski. This is a full custom build for one of my customers. Inside the bilge I've already finished and it's ready for a new 750 swap.
Magnum440d100
Indiana
Brought home these 2. One with seat runs. One without seat doesn’t. But has a deck.
Bought them both for $200 and the deal came with an additional/extra IC GOLD engine for the one that doesn’t run. But I’m going to possibly use it, or parts of the blown one, to fix the craftsman that some friends gave me a while ago.
Spending money basically Lmao
jblnut
In the Middle of MN
Finally got the access doors in the loft wall. Pops and I “discussed” if they should swing in or swing out longer than it took to frame them in and install them. I said it’s my damn shop and I want them to swing out !! That way when I inevitably pile too much junk up there I don’t have to move things to open them when I want to bring more stuff up there with the forklift. I plan to put tin over them or at least paint them so they don’t stand out quite so badly.
HPRifleman
Member Emeritus
Wayne, IL
That first step is a doozy!
kaymccampbell
Upstate New York
Paint the whole thing burple purple, you'll never notice the doors.
zanyad
NE Ohio
I'd have done the same. What was your father's rationale for the doors to swing in?
kaymccampbell
Upstate New York
Most accident averse folks make the doors swing in, and put at least 1 or 2 easily removable rails across the opening on the outside.
jblnut
In the Middle of MN
:lol_hitti These doors are for forklift access so I don't have to lug all my treasures up the stairs. There is another 3'0 door at the top of the landing for people.
Oh my goodness my eldest would love that !! She is bonkers about purple !!
Pops and I do "give me three reasons to do it that way" all the time and the three he gave were ...
1 - They will be hard to close and secure - No worries. I'll put a shelf bracket as a handle and a giant deadbolt deal top and bottom to hold them shut
2 - It'll look silly - Not your shop Pops. I think it'll be fine.
3 - They're hanging off in no man's land and will sag - WTF think about that one for a moment before I tell you the obvious about why that reason holds no value lol
Swing out makes them harder to open and close. My basement door is like this. To close it, you have to lean in to the stairway, reaching for the knob to pull it closed.
Since this side will only be visible when the doors are open and to whomever is upstairs I am fine with a little goofy looking stuff. These shelf brackets make nice handles to pull the doors shut.
Easily within reach when fully open. I will also have some bracket things on the center parts of the doors so I can pull them in the rest of the way and drop a 2x4 in that'll span the entire door width to keep them from opening if you lean/fall against them for some reason.
I figured over the next 50yrs (hopefully) I'll have **** piled in the way for them to open in so I am trying to plan ahead lol. I plan to put removable rails in the inside to keep them from opening and to keep it cleaner looking outside. I am waffling on painting them white or putting tin on them so they look just like the rest of the wall. I wonder if tin would be too heavy though :dunno:
kaymccampbell
Upstate New York
Tin will reinforce them. It'll probably be cheaper than the can of matching paint.
welder4956
Birmingham, AL USA
I noticed the compressor has been running more frequently over the last couple of weeks and bleeding down to zero pressure overnight. So, Monday I started investigating and found the $10 HF automatic compressor drain valve was leaking. At first it looked like the o-ring was blown out, but then I found a split in the threads next to the o-ring that caused it to blow out.
I started to make a run to HF for a replacement, but decided to see what other options were available. I found this drain valve made by Conrader on the Grainger website for $72 plus shipping. It is made in the USA and looks to be much better quality. The new drain valve kit was delivered yesterday evening and I installed it this morning. No more leaks so far, we'll see how it holds up.
Magnum440d100
Indiana
Confirmed the engine in the mower with the bad engine was indeed bad. I was able to push the piston down the hole with a screwdriver, turn the engine by hand, and the piston stayed down.
So it got yanked. I’ll be using the lower portion for the other engine that runs but the sump is broken. IMG_3561.jpeg
Then put the extra engine that came with the two mowers on the frame IMG_3560.jpeg
Starter was bad. Put a known good one on, and she runs on starting fluid. Fuel lines aren’t hooked up yet. But at least she will be a runner.
Tomorrow after work I’ll sort the fuel system.
Then I get to pull the mower my friends gave me into the garage and pull the engine to put the sump from this bad engine onto IT.
Too much work lmao
kaymccampbell
Upstate New York
Can't get the cheapies from HF any more.
CoogarXR
My garage has been dark the last two days. I pulled my back doing the "ductwork limbo" for several hours in a low basement Monday, and I've been laying on an ice pack and popping ibuprofen since. It's almost back to normal, thank goodness. I've got **** to do, I can't be laying around, lol. I went out and did some shopping today, did some walking, it's loosening up slowly. Getting old ***** when your brain still thinks it's 20.
Magnum440d100
Indiana
Well, this *****.
Got my friends mower pulled in the shop. I say friends because my friends gave it to me. IMG_3570.jpeg
Got the motor pulled, and while crawling under it…73335709843__DD7D7ECF-2226-466B-A63D-05B0333EA371.jpeg73335710929__A4ADAF94-08DE-47CF-95D0-24F0A39EDE0A.jpeg
Not the end of the world. I’ll weld her up. This one isn’t for sale because it was a gift. So I don’t have to worry about my junk welds breaking on a suspecting customer lmao
Went ahead and pulled the engine apart though. Yeah, sump is toast.73335845563__85CE2159-ED38-4E16-896E-AF269BB6A9BF.jpeg
So is the crank.
At least the sump looks good! 73335891366__1BE9D936-45D3-4D78-9821-12F7C1C49196.jpeg
So now to go to the evilBay and find a decently cheap crank.
Or or or…. Bigger engine time!
