Magnum440d100
One of the reasons I bought the pair of mowers was because one has a running 17(?)hp engine. Only 2hp bigger, but…This^^^ Big enough and its mower racing time!
Get some remnant fabrics and practice a bit. and peruse the Sewing Projects thread...Big job is Canvas and upholstery. Never done it or run a sewing machine- ye
They don't want a unsatisfied customer.
Apparent success! The home made spreader and a regular spreader did the trick. New remflex gaskets are in. Hopefully after a few heat cycles is still good.This is why we can't have nice things.
So my 93 K1500 had an exhaust manifold gasket leak. Years ago I had already had that manifold off. And I knew it would be a total ***** to get back on because it's got that warped thing going on that these manifolds get.
So I see the dorman replacement manifolds have excellent reviews everywhere I look. So against my better judgment I buy the replacement dorman part and this is what I got. Non existent exhaust ports. That's not going on my truck.
I don't want headers, so let's make this work. I have remflex gaskets on order, and a new spreader tool because mine is MIA. but those tools don't fit between 1 & 3, so I did this and it appears to have worked as I was able to bolt in in 1 & 3 now. 5 is still no good lol.
Now I wait for my order to arrive and have a dead truck in the driveway.
When I replaced the automatic drain valve on the compressor, the elbow for the drain tube was contacting the floor so I shimmed the compressor feet with 1/4" plates. Still think it needs more clearance so today I cut some spacers from scrap 4 x 4 to bolt to the anchors in the floor. Then I cut 3 3/16" steel plates, drilled 2 holes in each one to attach to the top of the 4 x 4, and welded a 1/2" x 2" bolt on each one to bolt the compressor feet down. Tomorrow I will test fit, paint and install.
Also sprayed primer and black paint on the engine cradle I made a couple of months ago.
I used a street ell. It was not the ell coming out of the tank, it was the one coming out the side of the automatic drain valve for the plastic condensate drain tubing.What kind of an elbow? I always use a street 90 because if the pipe gets broken it’ll break at the outside of the 90 and I won’t have to remove the broken piece from the bottom of the tank, just replace the street 90.
I need to make a system like that for making a pair of snowshoes and also a pair of sleigh runners.
Kind of fits with the old adage. "You get what you paid for."Lot's of people have been complaining about the cheap ($50) Ford trailer brake controllers you can buy on certain auction sites instead of from a licensed Ford Dealer ($230). I bought one of each to take them apart. Honestly, I don't think the cheap one is actually made by Ford. Same P/N and revision #. No heat sinking, different boards... no wonder why it doesn't work.
Did a full YouTube video comparing these two and an off-branded one. It's crazy there are manufacturers out there creating copies of units..
Here is a $100 unit. Some have had alleged overheating issues and melting according to the reviews.....
Nice. I had always used System 3 Yacht Primer, but found a deal on this Pettit from Campers World of all places. $40 for the gallon unit, cleaned them out. Nice product, I think I applied with a 1/8 mohair roller.The weather was just right, so I got 2 coats of epoxy "barrier" on the bottom and hood of the jet ski custom build. I like to roll the high build stuff on with foam rollers. No foggy overspray waste, and it builds thick in just a couple coats. Plenty on there to block flat.
It's a Wagner steamer off of Amazon. I do not recommend the pvc pipe, though. After an hour, it started sagging in the middle and it started to put off a smell. I opened all the shop doors to get a breeze through it.I need to make a system like that for making a pair of snowshoes and also a pair of sleigh runners.
Is that a steamer or something else that is being used as one?
