Main and sub pane-brands
bluedog225
Texas
Good morning. I picked up three 200 amp panels from Restore on two separate visits.
One is a brand new Siemens panel with a main breaker and a few smaller breakers. The other two look to be about 10-year-old GE panels. Full of breakers. They look like they are in very good shape.
I’ll need a main panel for my conex to be fed by my solar system inverter. And a sub panel at the cabin.
My question is whether I care which brand I use? I’m guessing I should use the two GE panels to be done.
For some reason I thought the Siemens panel was higher quality. I can always sell the GE panels and get another Siemens.
I’d appreciate any thoughts.
Norcal
There is Siemens, Eaton CH, SQ D QO, SQ D Homeline, GE, other then Eaton BR, which I would not put in a building I was going to have burned down in a practice burn the next day, I really don't care for GE, but would consider using them, unlike Eaton BR, but Siemens is not bad choice, but that is the choices out there, Siemens, good, but the interlock on the GE would be tempting.
wyliesdiesels
Modesto, CA
smh the first one is missing the interlock
the siemens is missing the buss bars to tie the output of the breaker to the busses
im not a fan of GE... their half width breakers are annoying
kinglew
Br panels are very good no issues ge is junk
AffableCurmudgeon
Triad Area NC
I don't know anything about this but it seems that the two tabs that are sticking out on the right hand side of the pictured 200 amp breaker, somehow fit into the top of the buss bars. Again, i could be completely wrong.
dcg9381
Austin, TX
I just try to keep all my panels on the same brand and breaker line.
I dunno what you paid for those, but that interlock looks like a brand I've bought that isn't inexpensive. Course if you don't need an interlock, having that feature doesn't give you much.
wyliesdiesels
Modesto, CA
those tabs look like bolt on lugs that would be bolted to a buss bar NOT something that would go into those lugs with a set screw.
wyliesdiesels
Modesto, CA
its probably a convertible ML panel. would need to change out the lugs to bolt-on style... but need to look up the panel model number to be sure its listed for that. hell that might not even be a 200a rated panel.... looks small for a 200a panel.
bluedog225
Texas
No big loss. $20-25 each. Fwiw, that 200 amp breaker fits under the upper set screws. It’s just sitting in the bottom of the box as shown. Can use the boxes elsewhere if they are no go for my system. I will get more detail on the box next time I’m up at the place.
