The Vintage New Britain and Associated Thread!
^ I see parts for that puller on ebay all the time. It was a model 248 Indestro. Everybody "made" one. (I think they all came out of the same plant, to be honest - they all look identical except for Snap-on and Herbrand.)
Mintgrun
Kingston, Wa.
7/8" I've got impact sockets that will fit it; but it needs to be deep, in order to clear the hammered-on part at the end, or it won't engage much of the hex.
^ and Craigslist. I see the "Hammer" thingie (that Mintgrun is missing) AND the "foot" thingies on ebay and Craigslist now and then. More on ebay, and more leg thingies than hammer thingies. (I think they actually had separate part numbers for each piece in the Indestro catalog on some of those pullers - you could order separate components.)(Which begs the question: would they show up in an OTC or "CTA" catalog?)
Some brands are different. The hex size and the leg to body hook. They do all look about the same.
^ oh yeah. right. hex on the top of the screw thingie varies, which means the hex opening on the hammer thingie would vary.
sorry. fuzzy memory on some of this stuff. we rented those old dinosaurs out all the time, believe it or not.
beatcad
NOVA
A friend gave me this little guy today. He saw it at a swap meet recently and remembered I like New Britain. The business cars is there for size reference. It could be 60s or 70s.
It'll go in my 60s tool box
Here's a 3/8 husky set still covered in BLO, I don't think it's ever been used.
Beerhippie
Far NE Oregon
A little something that followed me home yesterday:
Both ends of the bar are mushroomed from being used as a drift.
I have no idea what the extension is:
Thorsen (OK, I do have an idea--or a WAG)?
I thought the 1/2" dr 7/16" socket might be NB also, but looking closer, I see the knurling doesn't have the borders like the slider and are inverse:
As found:
^ yeah. Don's nailed it:
two dots, one on each side of size stamp: Sherman Klove (S-K)
two stars, one on each side of size stamp: Indestro (not sure if Duro-Chrome did that?)
I do not think that is Thorsen. :headscrat
Patrick Eubanks
This 1/4 (missing plug, no #) turned up, and it matched the mysterious 3/8 I previously posted. Same exact body size.
I simply don’t know where these fit into New Britain history. Definitely on the old end of the spectrum. Guessing 30’s over 40’s. Haven’t seen any documentation yet.
Not matching anything in the ’38 NB or ‘39 Craftsman cats online, as the images show long head female models at that time.
Very interesting. Very similar to the one I found
Lesserstore
Texas
I cleaned up this None Better socket set box last week. Got it for $5 at a garage sale. The set number, 1075, doesn't appear in any available online catalog, nor does the exact box style. The same boxes did show up in Craftsman 1939 and 1942 catalogs.
The military generally used Cosmolene for long term storage, BLO was often used on tools as it kept rust at bay and they ere usable without cleaning.
Beerhippie
Far NE Oregon
I use a light coat of BLO thinned 1:1 with mineral spirits on anything bare metal (or wood). You can hardly tell it's there, except for the not rusting part.
Try a 1/3 mix by weight of BLO/ beeswax/turpentine on wood handles. Infinitely repairable, easy to apply w a Scotch-Brite pad. Really great hand feel afterwards.
Oops, forgot, melt together in a double boiler, and probably outside
I'm guessing an electric "burner" might also be a good Idea. Open flame and BLO/Turpinetine fumes might be dicey?
Maybe a crock pot is enough heat for the beeswax?
  • Like
Reactions: RTM
Beerhippie
Far NE Oregon
If you whittle the wax down to small chips, it will dissolve--slooowly--at room temp. We used mineral spirits instead of turpentine, so not sure how much difference it would make.
Turpentine smells better. Room temperature here only makes a slurry, even with grating the wax prior.
I do have a single burner hotplate dedicated to garage stuff, but the propane has been called out in the prior times
MisterEd
Florida
M-105 Bendix Brake Tool
garilla
I'm a long time user of BLO and it is great for a lot of things, but one thing I can not recommend it for is on outside wood tables/chairs, it looks great at first but over time it will turn a deep black color, I researched why my table set did that and apparently something is living on the BLO and that thing (bacteria? fungus? ) is what makes it black. great for wood handles and metal though, just wouldn't keep it outdoors for long periods.
