Soldering stainless
Firebrick43
West central Indiana
jaw22w
indiana
I do a lot of soldering for stained glass projects. I know you can't solder anything to aluminum. I've tried. Unless there is some special flux or something.
You can solder steel to copper easily, but it seems to my hazy memory that I tried soldering stainless steel welding rod to copper for a stained glass deal and was unsuccessful. If I recall correctly the solder wouldn't stick to the SS.
Firebrick43
I have silver soldered lots of SS to copper/copper alloys such as brass and bronze. I assure you it works just fine.
J
JackOfDiamonds
Idaho (USA)
Looks like the bigger problem is finding copper.
It has to be copper... conductivity of copper is 400, aluminum is 200, brass is like 60. I didn't know conductivity of brass was so bad.
OccupantRJ
Eastern North Carolina
What form of copper do you need? A flat sheet can be obtained by cutting a length of copper pipe, splitting it, then flattening into a sheet. Annealing helps with this.
jaw22w
indiana
Well, I guess my memory was hazier than I thought. I was a certified arc welder but have no experience with gas torch welding. Is the brazing operation an oxy/acetylene process? My only experience with soldering is with an iron. It must take a lot more heat for the brazing operation.
Firebrick43
I always did it with a oxy/acetylene torch.
It’s also done on ovens and induction heaters(with iron/steel)
Rusty Wrench
I have soldered copper to stainless and brass many times. Many swear by Harris Stay Clean flux. I've used both Harris and paste flux successfully but for copper to stainless I'd prefer Harris. For stainless, depending on thickness, regular propane my not provide enough heat but MAPP gas or whatever it is now works fine. If the work is delicate hammer the solder flat for better control of application.
