zmotorsports
What are cross fire’s Mike?
Cam, Crossfire's are similar to the old Cat Eyes which go on dual wheel setups. These are devices that keep the tire pressures equalized between inner and outer duals. They also have a valve inside that snaps closed in the event of a blowout or if the tire pressure drops below a certain level to signify one of them is going flat so they don't both lose air pressure.
As I'm sure you know, on a dual tire setup it is imperative that both tires have the EXACT same circumference as they are bolted together at an axle end. If one tire for example, is even 5/16" difference in total tire circumference then the smaller tire in a dual setup will be dragged along. That 5/16" equates to approx. 13' per mile that it is being dragged, or 346 miles in 100k miles. As I'm sure you are also aware, that the inner duals always run the hottest as they are closer to the brake setups as well as have less air passing by for cooling. A mere 5 PSI pressure difference between an inner and outer dual can equate to 5/16" given in the example above.
So you can see that having the tire pressures equal is paramount in providing the tires the best chance for longevity as well as efficiency rolling down the highway.
The Crossfire's provide that benefit of keeping the tire pressures equalized. They are available in various pressures from 80 up to 120 PSI and should be matched to the correct tire pressure required based on the tire manufacturers' weight vs. tire pressure charts. I have ran these on all three of our coaches over the past 32 years of RV'ing. The first set I used Cat Eyes on our 19.5" tires/wheels on our 30' gasser then in 2000 when we purchased our first diesel pusher, a 38' Beaver Contessa, I bought the Balance Masters and Crossfire setups. I let the Crossfires go with the Beaver when we sold it as they required a different pressure than our current coach so I bought new ones to match the weight vs. pressure we required but I took the Balance Masters from the last coach and installed them on our Dynasty. I did have to replace the tag and drive axle Balance Masters over the years but the fronts have been in service for 24 years now between our current and last coach.
Not sure if it's me not being realistic with myself or if I am just that slow. While I feel I've slowed down a bit over the past few years, I don't think I've slowed that much.
