Old Classic Flat Bottom Wheelbarrow?
Beemer
Northeast
OldCarGuy
After decades of service... Time to retire my old wheelbarrow.. . No idea of its' age or maker; but it served me well.
Steel spoke run-flat wheel. Never needs air
Just purchased a Jackson 6 cubic foot model wheelbarrow. Comes standard with a “NEVER FLAT TIRE!” Nothing new here, I never had a flat tire with the ole time tested model with its' tough steel spoke wheel..
Beemer
Northeast
That steel wheel had to be a killer!
Or did the rubber disappear?
ATC
VA
and the pans are thin when new so they won't hold up to the weather.
Thanks for the hunt but that's why I mentioned the interest in a vintage one.
Buy two, and sandwitch the two pans together when assembling it. Then, you'll have spare handles and a tire/wheel.
Beemer
Northeast
I think we've beat this horse to death but some alternate ideas did come out of it.
Thanks for the replies.
OldCarGuy
The wheelbarrow just had a steel wheel,, no rubber. That's what I remember as a child as they were very common. Actually the solid steel wheel works better than one may think. Though it boggs down in soft mud. And had a tinny sound over concrete... Sure can hear you coming,,
OldCarGuy
Rather than put the old gal out to pasture, I decided to breath some more life in her. I welded a piece of 16 gauge steel in the tray, Welded up numerous holes in the frame. And pressed on some solid brass tubing I had standing in the corner of my shop. Then spray painted it with Rust-Oleum with hardener. Then a final automotive clear coat over everything..
I couldn't find the manufacturer nor the time it was built. So I just painted it to my liking's, and what paint I had on hand. I chose the yellow for the spoke wheel to emphasize it. I can remember wheelbarrows having the solid steel in the 1940's when I was a child...
Beemer
Northeast
Looks too pretty to use.
I'd have tree frogs in the handles if I had one like that here.
sz0k30
SE Michigan
Trying to hunt down an old fashioned flat bottom wheelbarrow.
They were generally all steel, low capacity, maybe 4 cu. ft. and were not bathtub shaped like all the current ones.
Any ideas where to look?
Just saw that one at Ace Hardware. About $60.
^ the one in the photo that @sz0k30 posted above (post #52) is the same model I bought at ACE Hardware about 8 years ago. MINE has plastic wedges right under the bed, but that's not the weak point.
The weak point is the cheezy handles, one of which snapped when I loaded the bed full of bricks.
I believe I paid about $40 bucks for it on sale.
Beemer
Northeast
I think a solution to handles might be replacement with specialty woodworking handle shop items.
I was looking at something like these: https://beaver-tooth.com/products/60-wheelbarrow-handles-new-pair-usa-replacement
I have an expensive commercial grade wheelbarrow and, guess what, one of the wooden handles needed replacement in about a year or so. I guess it's just like building cars. If they save 20 bucks per wheel barrow it adds up. It just doesn't make for confidence in the product line.
@Beemer - for less than $36.75, I can buy two pieces of one-inch angle iron long enough to support the cheesy handles and never have to worry about it again. I just haven't gotten to it because .... I try to avoid doing stuff that requires the use of the wheelbarrow.
Maybe I'll get to it later this summer.
Beemer
Northeast
Probably for less. We have a large surplus and used steel warehouse nearby. It's just out of character though.
Oh, that's House Handle Company. Read about that.
So how were the handles?
I like them. I bought them after mine broke under load. Bought it used, doubled my investment in the wheelbarrow.
Only hard part was deciding where to put / cut the wedges they supplied.
Straight as can be, white oak should hold up longer than the tub at this point.
Beemer
Northeast
I presume what appears as wedges sitting atop the main handles are loose wedges, right?
What did you use for a finish on the oak?
I don’t recall, I may have done a mix of equal parts by weight BLO, beeswax, and turpentine melted together, then wiped on.
Or I did nothing, been a few years, probably need to redo it.
sz0k30
SE Michigan
After seeing this original post, I looked at mine and it needed work, so I decided to rebuild it. My father originally bought it in 1971, so 53 years old. The original tire was no longer roadworthy, bought a new one at harbor Freight for $17. Bought oak handles on ebay for $55 (real nice 1-1/2 square, but I had to plug and redrill 4 holes). Had to make my own wedges by cutting a 2x4 diagonally. Painted the pan. New carriage bolts, since I had to cut the original ones off. So all in for approx $80.
