paredown
One of those things that seems hard to find. The copper trade folks have a CAD drawing (but no template of the flat layout starting point) and most of what I can find presumes that you are working on a commercial flat roof, typically with a parapet where you are going through it, so the scuppers are closed.
Mine is a flat roof, where you use an open scupper that goes into a downspout collector (or sometimes into a gutter run.
The problem I'm trying to address is that the ones that are currently in place are too high relative to the roof deck, and one does not drain very well (until there is a lot of water ponding) and the second drains a little better, but is still higher than the roof deck.
I snagged two pictures off a roofer's web site (of an install)--I'm looking for a supplier who makes these. These are going into gutter box
Doesn't have to be copper, but will use that if necessary.
(Alternately a usable template for flat cutting and solder and I could probably make one out of copper...)
