Deck board edge question
WhoWhatNow
Collegeville, PA
I am going to replace the pressure treated board on my elevated deck. The existing boards are standard 2x6 pressure treated wood. I plan to edge screw the boards to the joists to minimize popping nails/screws. I really like the rounded edges on the 5/4 decking, however the existing decking height is at the perfect height to the back door. There is essentially no step up to the door threshold. This is important because my elderly mother lives with us. I do not want even a 1/2” step down for her to have to navigate that I would create if I used the 5/4” material. My question is can I round over the edges of the standard 2x6 PT similar to the 5/4” decking. I estimate that I will need about 57 16 foot pieces for the entire deck. We spend a good amount of time on the deck barefoot and think the rounded edges will help with comfort. Any reason not to do this?
I have no interest in using composite decking btw.
Joe Reed
Cordova TN
Sure....if you have a router and round over bit and are willing to do almost 1/2 mile of boards (both sides and both ends). Might take a little while....and probably more than one bit...
Higgins
Shepheardsville, KY
Not a problem. Just get a med to large router, a couple bits and away you go!
In our previous house did over 150 ft. took a couple of afternoons as i let the router cool down!
cgrutt
A few thoughts...
Routing will probably not cut into untreated lumber but its still possible and will likely diminish water protection on all the boards to some degree. May want to retreat exposed edges or stain boards afterwards.
Routing while wood is wet (which is often the case with PT lumber) may cause cuts not to be smooth or burns.
Routing by hand will follow any defects, voids, dents, knots, etc in the boards may have better results on a table.
Wear a respirator as all the dust will be loaded with chemicals.
manwithtools
Lebanon, TN
A few thoughts...
Couple of points to consider here. The treated deck boards he will be buying in PA will undoubtedly be SYP; with the treatment all the way through the boards. Routing the edge will not diminish protection at all.
Also, hand held routing is the only way to do this effectively. Give some thought to how it would be almost impossible to pass a 16' wet treated 2x6 over a router table and achieve any kind of even edge? The boards will not be straight or flat and very heavy. You literally want the hand held router to follow the edge of the board. Any other method will not work.
Skiff Builder
Southern NJ Coast
You can get radius edge 2x6 treated. Talk to your lumber yard or search google.
jar944
Northern VA
First choice would be radius edge 2x6 decking.
Second choice would be a short fence, power feed on a large shaper (not that I'd personally run wet PT on a shaper)
Third choice is a router and round over bit. It's only ~1850 lineal feet.. that's a lot BTW.
wssix99
Chicago, IL
Yes, you can rout the edges. I do this all the time, particularly with handrails. I find that it keeps splinters down on those edges. I also route the corners of my posts sometimes for a nicer custom profile.
Renegade1LI
long island ny
How you set yourself up will determine how long it takes. Two sets of horses with a stack on each 3 or 4 across. A good 1 1/2 hp router with two bits you'll bang it out in no time.
Rusted Nut
Northern Arizona
2x6 S4S (surfaced four sides). Rounding square edged 2x6 PT will cut off the treatment. You could use 5/4 x 4, just put some increasing size shims on the last 6 boards.
Kaizen
New England
I just did this with cedar that i used for railings. I still had to sand everything with two grits to get the smooth that i wanted.
I would not suggest it on pt. For starters unless you can get some specail 2x6s you are dealing with framing lumber. Its going to have uneven edges, missing knots on edge, and a host of other issues. Also I'm not sure how the roundover will deal with the moisture. Some of that stuff is dripping wet. I originally was going to use it for handrails as the local lumber place had 2x6x8 cedar at more then the price of mahogany. But when i looked at it in the store i saw the pt would never be nice
W
WhoWhatNow
Collegeville, PA
Thanks for the ideas everyone. I did not realize you could get 2x6 radius edge boards. Unfortunately, Lowe’s and HD appear to be out of stock. I will call around to some of the local lumber yards first.
If I can’t source the radius boards will give routing them a try. I will probably buy a base for my Porter Cable 890 and a few bits. A respirator and a long day will hopefully be all I need to get it knocked out.
manwithtools
Lebanon, TN
This is not true. It's very location dependent. The treated wood east of the Rockies is completely different than that available on the west coast. It's not the brown incised surface treatment you are used to seeing in the PNW. It's a pressurized treatment that penetrates the entire SYP board. It looks yellow or light green, it's wet and makes the boards very heavy when fresh, after 6 months or so, it dries out quite a bit.
screenshot_20240410_115846_chrome-jpg.2091147
dave*99
Coastal NJ
I read the title and I look at the photo and my eyes see a 5/4 board there. I'm not saying radius edge 2x6 does not exist, or that the ad would not get you a 2x6, but that photo just looks a bit off to me. YMMV
manwithtools
Lebanon, TN
That is just a stock photo from a website. I linked to it from post #9. Here is a picture of the real thing, taken from my garage just a few minutes ago. It does exist...
dave*99
Coastal NJ
Do you have a photo of those installed on a deck? I'm curious as to the look of them.
I've done plenty of 5/4 and plenty of standard 2x6 for decking, but not a radiused edge 2x6.
manwithtools
Lebanon, TN
Unfortunately I do not have any pictures of it installed as decking. This piece was a leftover scrap that my son had for some reason other than a deck surface, I think he may have used this for a top rail on the permitter of his deck.
Kaizen
New England
is that just regular wood or a lesser amount of pressure treatment? I thought all pt is for ground contact. I've never seen anything like that
manwithtools
Lebanon, TN
It's a lower pressure treatment, not all treated is ground contact rated. The supplier of this wood is Sunbelt Forrest Products, here is a screens hot showing the deck boards are available in above ground and ground contact ratings.
Wiz02
Southeastern PA
I'm in your neck of the woods. I have heard good things about Tague lumber, if they aren't already on your list, consider giving them a call.
