I assume this timing light uses an inductive pickup... 16 volts isn't very far above the peak "normal" voltages seen in 12V systems; the odds are very good you'd get away with it w/o any issues. However, Zendriver has a sure no fire solution.
16V systems are common in drag racing, for more juice to the ignition system.16v is probably fine but without knowing anything about the specific circuit I wouldn't risk it. I'd just use a separate 12v battery as others have suggested. I'm very curious about this 16 volt car. I've been messing with cars for a long time and I've never heard of such a thing.
Edit: Just after I hit the post button I remembered the 16v turbostart batteries that some drag racers use.
I tend to agree and the increased voltage might make the flash brighter(always a good thing outdoors)but at the expense of the bulb. That is a reasobably expensive timing light so to be safe I'd use another power source or a device to step down the voltage. One of those old slim 12v Makita battery packs could probably be strapped to the light. Hopefully someone familiar with the actual workings will chime in.I assume this timing light uses an inductive pickup... 16 volts isn't very far above the peak "normal" voltages seen in 12V systems; the odds are very good you'd get away with it w/o any issues. However, Zendriver has a sure no fire solution.
I still have my snap-on one, however it dosen't get used much these days.Don't forget a flexible allen screwdriver for setting the dwell thru the pop-up window of the distributor cap, and a dwell meter!
I figured the same - but then I wondered, is a 16v car also charging at an even higher voltage? Or maybe this isn't the sort of car that has an alternator...I know it's safe up to 15v since it's timed while the alternator is running. I would think 16 would be safe, but I don't know for certain.
Or a cigarette lighter and companion USB port.I figured the same - but then I wondered, is a 16v car also charging at an even higher voltage? Or maybe this isn't the sort of car that has an alternator...
