Above 1200 Sq/FT Garage Refurb®
jbmatth
Northern Ok.
I made 4 similar clamps but used the H.F. version, they work great for about everything but exhaust tubing, that is still a battle I haven't won completely. You will love having those when you use the table.
JB
N
NUTTSGT
Northern Central Ohio
JB
I'm considering using a muffler clamp of the appropriate sized to make a pipe clamp adapter for these clamps.
I have an exhaust project coming up in the future so we will see.
jbmatth
Northern Ok.
That was basically my plan as well, but have worked on as small as 1-5/8" up to 4" exhaust so it became a little more complicated. I guess it all worked out in the end though just using scrap wood with the clamps I already made.
JB
Bob Heine
Boca Raton, Florida
JB
I've been using a standalone Strong Hand V-clamp to hold exhaust tubing.
Strong Hand sells just the V part with various mounting options and materials. Some have magnets embedded in the pads.
I've also used exhaust welding clamps to tack the exhaust tubing.
You could save a bunch of money by cutting windows in the regular band clamps.
N
NUTTSGT
I was going to buy a set of the Strong Hand clamps but found a similar type of clamp on Amazon. I figured I would try them first for about half the money. I'm not sure this 3" exhaust build is even going to go well.
burger
Erf
My Intent was to finish up the mobile base for the saw but I think my hip had some inflammation and I didn't get much else done.
Man, bummer. I hate injury. I have a compressed nerve in my left thigh/groin area and it *****. Sitting down is uncomfortable. Work was awesome though and got me a sweet standing desk.
N
NUTTSGT
Time to go to your list to see what other "trouble" you can get into! :unsure:
I have a list but I also have a chiropractor appt this morning. If all goes well, I need to do a few things outside which include the JD and dump trailer. I'm not sure if I'll be able to do that after the appt.
. . . . I have no issue finding trouble, I'm quite well versed in that aspect.
N
NUTTSGT
The Relton Stick Kut is exactly what I have been using for the past decade or so Eric. Works well and doesn't take much.
I bought it on your recommendation Mike. So far, it's been great.
On the flip side, I have an unused gallon of cutting oil I will be taking back to Menards for a credit.
N
NUTTSGT
I like it! Do you use bed frame for something like this?
No, I had some angle iron already but picked up another 8-9' stick along with the flat bar at a local machine shop.
They're an "Amish" fab shop and good people. I've started getting all my steel from them. They have some nice equipment and plenty of stock on hand for the fab business.
A few months ago when I stopped, there was a piece of 3/4" plate 8-10' wide and 20' long sitting outside, I can't fathom what that piece of steel cost.
burger
Erf
This is probably a really dumb and obvious question, but what on that press, what does the 20” refer to?
Johanfpa
Aberdeen Scotland
Not a dumb or an obvious question at al, the 20” number represents the max distance from spindle to column aka "swing" of the machine, which is from the column to the centre of the chuck, times two.
So that represents the maximum diameter of a workpiece that can be drilled dead centre.
Some folks think that the number is the max drilling height, but it is actually the swing of the machine it is referring to.
N
NUTTSGT
Very good explanation. Thank you.
This distance can make a big difference when trying to drill a hole in a large object or plate. Basically it's just a deeper work area to the column. Maybe I'll get a few pictures later today.
burger
Erf
Thanks for the explanation. I’ll have to measure mine when I get home.
N
NUTTSGT
With all the cool things you build, it might be time for a small lathe. Maybe an old Craftsman/Atlas like I have. It would really be cool to see you put it to work with your projects!
Funny you mention it, been talking to a guy at work about it. After I lost an auction last week for a Wilton drill press, I was considering a vertical mill.
N
NUTTSGT
Eric, bumper looks great.
Thank you.
I was hoping the table on the drill press would clean up easily and for only a few minutes of work, this is what I had.
Since I had no elevating crank for the table, I improvised and robbed the crank off the old horizontal bandsaw. Rather than it going to the scrap yard, I repurposed it. I had to drill out the hole and ream it out a touch.
