toddwallac
I built a 24x12 shed/workshop for my leather working.. shed uses smart siding.. insulation between studs and sheetrock interior. roof is pretty much flat with that roll on asphalt roofing and ICE and Water barrier under it. the decking is the solar barrier (silver backing).. I have the roof insulated as well and a wood tongue and grove on the ceiling.
I have been using a Black and decker 14,000 BTU portable AC and its just not keeping up.. I then added to 10" attic fans at each end of the shed.. ceiling fan to move the air around. sealed doors and all around the room line..
The shed runs a few degrees cooler than outside temp but we are now in the 90's in texas.. I was thinking about running some more electrical out to the shed and add a split AC unit but really didn't want to doll out more cash if I don't need to.. I thought the 14,000 portable AC should be able to keep up but its really not.. Shed takes direct heat.. outside temp is now in the 90's.. When I hit the walls with a laser temp, they show around 90.. inside the shed is like 88..
Any thoughts before I spend the money on the split unit AC?
