Milwaukee M18 Battery Issue
D45
NW INDIANA
I have an XC5.0 M18 battery
Used it alot demo-ing a deck with my Sawzall two weeks ago
Power button says it dead b8t when I put it on the charger, within 2 minutes it's green.......yet it's still dead
Battery is maybe 2 years old
I tried jumping it with a fully charged M18 with no luck
Any ideas or suggestions?
darkzero
SoCal
Yep, dead cells or out of balance. Check the voltage of the 5 banks to see if any are dead or severely out of balance. I was lucky & I only had unbalanced banks on 2 of my M18 5.0s which are 9 years old. Rebalanced them & they have been working fine ever since.
But in your case if only 2 yrs old, I would send it in for warranty. The same happened to my M18 8.0 but it was barely still in warranty so I sent it in. MW sent me a new one.
dnschmidt
Phoenix, AZ
It has a warrantee so use it. 1-800-SAWDUST is your friend. One caution. If you have the receipt you're golden otherwise they will go by the date of manufacture on the battery and that might be older than three years. If that's the case you're screwed. This is why you should also keep the receipts when you buy Milwaukee batteries.
mattthemuppet
San Antonio TX/ Spartanburg SC
As above, open it up and check the individual banks of cells. I’d gutted that one or more is low. Change them up separately and you should be good to go. Happens occasionally on one of mine if it discharges too low. I make sure I only use it on my impact driver
oldschoolcraft
Bay Area, California
There's a date code on the battery. The warranty lasts 3 years from date of purchase (based on receipt), or in the case of no receipt, then it's based on the production date on the battery. Check that, if it's within 3 years, you might be good.
I wouldn't tell them you found it in a pawn shop though, the warranty might only apply to original buyer, technically.
D
D45
NW INDIANA
Here's the bottom of the battery
darkzero
SoCal
That is an older generation battery, the date code on those is the heat stamp on top of the battery, first 2 digits is the year. Regardless, it's well out of warranty.
dnschmidt
Phoenix, AZ
How the hell do you beat up a battery that badly? Did you run it over with a bulldozer? That battery is likely at least 10 years old.
D
D45
NW INDIANA
Demo'd a 25' x 20' deck with a Sawzall
Pawn shop batteries are half the price of new
Looks like it's time to shop on ebay for an open box or used one
Open box XC5.0 batteries are $47-$55 shipped
D
D45
NW INDIANA
Replacement battery will be delivered tomorrow, open box from ebay
In the meantime I'll crack open the old battery to do some inspection
