Good to know - I'll be using it for mechanic work so that's good to know.A fair price. Kennedy boxes are well made. Just check the caster mounting surface. Most were very weak as they were made for machinists. But the red ones were for mechanics and the one I have is solid.
That makes me feel better! What would you recommend to clean it? I know they have that crinkle paint on em.It is not a rip-off if you negotiated and made that offer. The toolbox needs a good cleaning and it should look fantastic.
Kennedy boxes always support higher pricing. I could sell that box in a few minutes, here. I would ask, $400 and take an offer of $350.
I would recommend Simple Green mixed in warm water. Scrub with a brush and flush.That makes me feel better! What would you recommend to clean it? I know they have that crinkle paint on them.
That Kennedy wrinkle cleans up real good with WD-40. Leaves a shiny finish too.That makes me feel better! What would you recommend to clean it? I know they have that crinkle paint on em.
They made a red wrinkle for a little while too.I think the red ones are smooth. 20 years ago I got a brown one. Then you could get the same box red or brown
The only difference between that red one and a brown one is the paint color. Period. They called them mechanics boxes as they were sold to large facilities that used different color boxes for different trades in the place.
That's the rarely seen 8 drawer bottom and a highly desirable top box too. I'd call that a great price if everything works good, but not necessarily ideal for modern auto mechanic tools.
That's not true.The only difference between that red one and a brown one is the paint color. Period. They called them mechanics boxes as they were sold to large facilities that used different color boxes for different trades in the place.
So, did you get it?
I've had a lot of Kennedys. Every red one I ever had, I could look up the exact same box in brown. I think the only difference was an R in the part number or something.That's not true.
The mechanic's series has deeper drawers and different drawer configurations altogether. Particularly with the top boxes. The bottom boxes may have been the same save the paint color, but the top boxes are very different.
At some point they started offering gloss red too like you mention. Don't see many of those in the wild.I think the red ones are smooth. 20 years ago I got a brown one. Then you could get the same box red or brown
It's probably more accurate to say the machinist's line was distinct from the rest of their offerings. They only made the machinist boxes in brown, and they were very specific to machinist type work.I've had a lot of Kennedys. Every red one I ever had, I could look up the exact same box in brown. I think the only difference was an R in the part number or something.
Also had original old literature that showed same boxes in either color. If you're saying there were a few top boxes offered in red only years ago, I could believe that.
For 99% of what anybody is going to come across on these old Kennedys, they are the same exact box, in my experience.
I did the steel plate on my Kennedy roller when I got it.That Kennedy wrinkle cleans up real good with WD-40. Leaves a shiny finish too.
You can strengthen the caster surface by putting a piece of 1/4" steel plate between the casters and the bottom surface. You could even use aluminum plate.
You’re not wrong. The mechanic line was available in brown, red, a really cool green for a hot second, and now blue with the Cornwell takeover. That would probably explain why the other poster believes they’re all the same since it was very possible to run into the same box in different colors. The machinist boxes have always been brown. You’d know the difference because the machinist boxes had the felt lining and the brown plastic pulls while the mechanic chests had less drawers and aluminum pulls.It's probably more accurate to say the machinist's line was distinct from the rest of their offerings. They only made the machinist boxes in brown, and they were very specific to machinist type work.
They offered the mechanic's line in wrinkle brown as well, but the mechanic's line was distinct from the machinist line. AFAIK, only the mechanics boxes were available in red.
The mechanic's series had bigger drawer pulls, deeper drawers to accommodate bigger tools and on some boxes ball bearing slides. They were very different than the typical and common machinist box.
Nowadays they make the distinction with the "signature series" as the box for the machinist and the "k series" as their generic general purpose box.
Yeah, the Maintenance Pro series of boxes is pretty cool. I believe they had one with a set of larger inflatable tires in the middle of the box so you could pivot the box on it's center axis and maneuver the box in tight spaces.Ok after looking at more old literature I see where I was applying the term machinist box inaccurately. Can't believe I never noticed how they used the term mechanic's box before.
Also, I've seen a couple of yellow ones that I believe were factory paint. Bigger boxes from that industrial line they used to make. I think they called them maintenance boxes.
