Help with garage / shop lighting layout
TimberMan
I am getting ready to have my attached garage / shop electrical trim out started and need to quickly finalize the ceiling light layout and order the fixtures. I have attached a screen shot for clarity but the summary is that my space is 26' x 36' with 13' ceilings. I plan to use the bottom third of the garage (the single door area) as my wood shop for a year or two until I build a detached shop. The electricians have roughed in the wiring with 6 penetrations in the drywall as shown with the circles on the file and I have two drop beams in the shop area shown in dashed lines so fixtures in that area will likely need to be suspended.
Any advice on how many lumens I need, how many fixtures I need and what type / size / brand will be greatly appreciated! Thanks.
Colin Gao
just did a layout for u , u need 2*2 150W ufo high bay.
zmotorsports
Northern Utah
One additional to think about when finalizing light fixture layout is to know what you are going to have under them and not rely solely on the mapping some lighting manufacturers provide. Most use a generic or even spacing and depending on the shop/garage's intended use, that may not be ideal. I ended up tweaking mine a bit and moving the fixtures some from where the layout map suggested.
By that I mean, if you are working on cars, you don't necessarily want the light directly over the center of the car and depending on how you pull the cars in, the generic spacing may place them directly over the center which casts shadows on the side where most of the work is done. When looking at my layout, I knew how far off the wall my cupboards were going to be placed and then where the cars would be spaced in relation. From there I adjusted the fixture layout over the spacing between the sides of the vehicles and the cupboards so I didn't cast shadows down alongside the vehicles. This allowed the majority of the light to actually get all the way to the floor and I seldom need drop lights now compared to my old shop.
Similar with where I spaced them over my machining and fabrication area, I placed the lights between the mill and lathe bathing the light down on the areas of the machines where I'd be working and not have the head of the mill block lighting or having the light miss my fabrication table, etc.
Just something else to think about when determining light fixture layout.
kneppb
Great information. Thank you. Mine will be mostly storage and some small projects, nothing too crazy. But I do like to have enough light, I can't stand when it is dark when I am trying to work on something.
