Extension cable for welder
willy3486
Middle Tennessee
I have one of the older Lincoln AC225 arc welders,probably from the 70s. They only put a cable maybe 4 feet for the 220 in. I have made a table for the welder that it mounts under. I can roll it outside so I can weld. But I need to make a extension cable of about 10 feet. I need to make a extension cable so I can take it to the outside of my shop. I know I will need stranded but what size do I need? Would I need to go with 10/2 , 8/2, 6/2?
Norcal
I made mine out of 10/2 wire. Menards sells it in a roll of 25ft if I remember correctly.
10/2 would be Romex (NM) or UF cable, a flexible cord would be 10/3 as all conductors are counted.
fflintstone
MOFnowhere Mi.
you want to use a 6GA cable for 50A
make it at least 25' long. you will kick yourself @ 10'
I made mine 30' and wish it was 50'
nate379
Palmer, AK
My cord is either 75 or 100 ft and it seems to be about the right length. It's nice to be able to wheel the welder outside and work in the driveway if I need to.
Stuart in MN
Minneapolis
What wire gauge did Lincoln use for the power cord that's on it now? For an extension cord that's going to be only ten feet long I'd just use the same size wire.
Norcal
Not really a good idea, the conductors are prob. 12 AWG.
AussieDan
Syracuse, NY
jam0o0
Katy, TX
when in doubt with welders get the bigger cord. you will thank yourself later. or actually you wont. because with the right cord you will never know you are using it. with a cord that is even a little too small you will notice in the quality of weld and the penetration you can get.
kenikh
If you can, buy one of these and never look back:
Welder Extension Cord
OOOOOOOHHH...tasty:
nate379
Palmer, AK
I have to wonder how they don't loose money on that. The ends are about $40 on their own and the cord is about $2-2.25ft.
25ft would not be big enough to get around my garage though. I would say you need at least 50ft to be comfortable. Nothing ***** more than welding with the welder wheeled out as far as it will go and the leads pulled tight!... and then your Dad telling you he has about 500ft of extension cord in storage... why didn't I go get a piece?
mrchuck
Gun Barrel City, TX
I have the same old welder. Super heavy copper windings. I use a 50' extension I got from my welding supplier and it performs flawlessly!
This length gives me the length to work over my boat trailers, or any project needing it.
The welder stays inside the shop, next to the door.
W
willy3486
Middle Tennessee
Talk about luck. I was off today and decieded to go out and clean my car area of my workshop. I also store other stuff like electrical in there as well. I needed to clean my shop because I made a new welding cart and I am putting in a parts washer I am fixing up for in there as well. So I had to move a few things to get it all to fit. I was cleaning a area where I store all kinds of wires and I went through to recycle the older wire. I found a really nice 3 wire cable that is a bigger gauge than the welder. I also have some ends so I can make one to use and not have to get one. I didn't remember the wire and I have no idea where it came from . Thanks for all the info folks.
