evening all,
need some help Id'ing a seal as it is leaking and local shop can't source it
Seal OD 140mm
seal Id to outside of seat 108mm
seal Id to inside of seat 106.8mm
seal thickness frount to back 14.8mm
material of construction: housing is made of steel with rubber seat which rotates
numbers on seal 104160 0 8ABO02894BY MADE IN BRAZIL
Seal came from an Braseixos (Rockwell) PRA-181 axle and is a rotary seal preventing the oil from leaking past the hub shaft and out onto the ground
Braseixos (Rockwell) are now owned by Axletech?
there is a trademark on the seal it looks like a "Y" imposed on a "Y"
anyone any ideas? don't see the seal listed here either https://www.offhighwayplus.com/Docs/2010Parts.pdf
will try and get some pictures of seal and trademark when I figure out how to get them off my phone and onto computer
seal is in the hub of a volvo L30 loading shovel, want to avoid going to Volvo for the part hence the question
regards,
aidan
Seal OD 140mm
regards,
aidan
