Question: Are the Bahco XXXXSL (For example, 8150SL) amazonlink
The same mechanism but also quick release compared to the original 8150? I've seen conflicting data on whether these are 80tooth or 72 tooth.
I have all three styles including the Snap On version. Can confirm, as the other person mentioned, the SL style Bahco ratchets are 72 teeth while the sealed head and Snap On Dual 80 style ratchets are 80 teeth, except the 1/4" drive version of the Dual 80 ratchets which are also 72 teeth.72, those with 80 teeth are those with a sealed head type Snap_on, except for 1/4, which is 72.
Just wanted to double check that the MAC axis ratchets are in fact the proto precision ratchets. I lost my mac one today off my service truck and pretty bummed about it hahaha. They both have the same specs.
They are indeed sister ratchets, made in the same factory in Dallas, TX. Only differences are minor ones - handle style (knurling on Proto, while MACs are available in comfort grip handles as well), and the engraving on the heads. The heads are otherwise identical, as is the finish on both ratchets. I don't know why Proto's product images make the Precision 90 ratchets look like they have a satin finish - they don't, they are full polish chrome. Same selector switch and same internals, both using 90 tooth gears.Just wanted to double check that the MAC axis ratchets are in fact the proto precision ratchets. I lost my mac one today off my service truck and pretty bummed about it hahaha.
Also, the entire heads if the SL style ratchets are smaller than the internals of the Dual 80 ratchets so they are definitely not the same. They feel different when ratcheting too. The SL is louder and not as smooth. The ratcheting noise is a bit higher pitched, like a baseball card in bicycle spokes. I know the Bahco sealed head is made in Spain and the Snap On is made in US, but I don't know for sure where the SL is made.
I was going to take it apart to post a few pictures of the SL internals, but I have no idea how to remove that blind circlip without damaging it out the ratchet, and if I'm going to damage it, I'd rather it be in the line of duty or for an actually attempted repair.
Sent from my Pixel 2 using The Garage Journal mobile app
Matco tools Sad106ta
Who makes these?
Who makes these?
Isn't Matco part of the Apex Tool Group? If so, the Gearwrench 80305 would be the cross to this Matco set. Here is a link to Amazon: https://www.amazon.com/dp/B000NICEVC/?tag=atomicindus08-20
No, Matco hasn't had any connection to Apex since Danaher/cooper owned them all. DANAHER sold Apex to Bain Capital but retained Matco, Keithley, tektronix, Fluke, etc. DANAHER did a "spin off" not too long ago so now those companies are under another publicly traded entity called Forgive. https://www.fortive.com/our-businesses/business-directoryIsn't Matco part of the Apex Tool Group? If so, the Gearwrench 80305 would be the cross to this Matco set. Here is a link to Amazon: https://www.amazon.com/dp/B000NICEVC/?tag=atomicindus08-20
Sent from my ASUS_I01WDX using Tapatalk
Snap-on/Blue Point
Wrenches:
BLPCWS711B 11pc BP Combo Wrench Set (3/8"-1") - Williams 11007
I see that the Williams 11007 is made in Taiwan and it makes sense if it is the crossover for Bluepoint.
Williams WS-1171SCA is made in USA - does anybody know if this is a direct copy of the Snap On wrenches?
Thank you,
Mark
IDK, but that sure looks like a Flank Drive Plus on the open end.
Great thread
This K Tool International extendable breaker bar is the same as the Snap On Bluepoint BLPBB1224.
https://www.amazon.com/gp/aw/d/B003TSW2V0/ref=ox_sc_act_image_1?smid=A2HFXLR2UUDL44&psc=1
https://shop.snapon.com/product/Bre...Drive-12-24"-Adjustable-Breaker-Bar/BLPBB1224
this is the 40 dollar version of a light MAC sells for almost 160 dollars, I didn't pay 160 for the MAC one, but I do own one, and one of these too.
E-Z Red XL3300 Cob Extreme Rechargeable Work Light, 450/250 Lumens, Red | ToolDiscounter
Cob Extreme Rechargeable Work Light, 450/250 Lumens, Red. Shop E-Z Red Cob Extreme Rechargeable Work Light, 450/250 Lumens, Red at ToolDiscounterwww.tooldiscounter.com
MAC is notorious for re-boxed or brand it with our name tool offerings.
I really like this light. One issue, at least in the ez-red version, is the battery does not seem to be "protected". And if fully discharged (light left on), the electronics will refuse to charge it.
If that happens, your options are somewhat limited. There are some tricks to force-charging these lions, I don't recommend it.
I was able to track down a replacement. It's not a standard 3.7 lion, and the connector is proprietary as well. I bought the battery below, and (CAREFULLY) spliced the OEM connector onto the new battery. The new battery is protected, and in theory should shut the battery down before the charge gets too low.
It’s actually two cells. There are kits to “make” something like this but there isn’t enough room for the casing.That's an 18650 Li-ion cell with a pigtail attached.
