The Truck Tool Equivalents Thread 2.0 - Expanded with Part Numbers
powerstrokin
Asked in another thread, but is there somewhere to see all these listings easily instead of going through here? Thanks!
mrspeed
Question: Are the Bahco XXXXSL (For example, 8150SL) amazonlink
The same mechanism but also quick release compared to the original 8150? I've seen conflicting data on whether these are 80tooth or 72 tooth.
72, those with 80 teeth are those with a sealed head type Snap_on, except for 1/4, which is 72.
I have all three styles including the Snap On version. Can confirm, as the other person mentioned, the SL style Bahco ratchets are 72 teeth while the sealed head and Snap On Dual 80 style ratchets are 80 teeth, except the 1/4" drive version of the Dual 80 ratchets which are also 72 teeth.
Also, the entire heads if the SL style ratchets are smaller than the internals of the Dual 80 ratchets so they are definitely not the same. They feel different when ratcheting too. The SL is louder and not as smooth. The ratcheting noise is a bit higher pitched, like a baseball card in bicycle spokes. I know the Bahco sealed head is made in Spain and the Snap On is made in US, but I don't know for sure where the SL is made.
I was going to take it apart to post a few pictures of the SL internals, but I have no idea how to remove that blind circlip without damaging it out the ratchet, and if I'm going to damage it, I'd rather it be in the line of duty or for an actually attempted repair.
Sent from my Pixel 2 using The Garage Journal mobile app
Contract_Pilot
Vancouver, WA
Hey anyone know of a comparable timing light / analyzer to the snap-on EETL500
Tripn88
Houston
Just wanted to double check that the MAC axis ratchets are in fact the proto precision ratchets. I lost my mac one today off my service truck and pretty bummed about it hahaha.
They both have the same specs.
BrandoJames
Tornado Alley
Just wanted to double check that the MAC axis ratchets are in fact the proto precision ratchets. I lost my mac one today off my service truck and pretty bummed about it hahaha. They both have the same specs.
I think both lines are owned by SB&D, but the two pix you posted look like different ratchets, particularly the handle & finish. The Proto knurled handle is rather unique; the Mac handle reminds me more of the Snap-on/Williams chrome handle.
javyLSU
New Haven, CT
They are indeed sister ratchets, made in the same factory in Dallas, TX. Only differences are minor ones - handle style (knurling on Proto, while MACs are available in comfort grip handles as well), and the engraving on the heads. The heads are otherwise identical, as is the finish on both ratchets. I don't know why Proto's product images make the Precision 90 ratchets look like they have a satin finish - they don't, they are full polish chrome. Same selector switch and same internals, both using 90 tooth gears.
Tripn88
Houston
The mac guy showed up and I just bought another one. The new axis ratchets have screws all the way through the heads now so they dont look the same. I was pretty disappointed how they changed it like that. I assume they had problems with the small torx heads and gaskets or something. The mac and proto are exactly the same price around here.
Old part number is xr1390k and the new part number is xr1390ak. Price went up 10 to 15 bucks as well.
I appreciate yalls replys.
Kasal
Galicia, España
if that is correct the sl versions are 72 teeth. I only have the version of 1/2 came with an extension and 3 socket, I remember that it was made in Argentina but I don't know if it was the set or just the socket.
Stick-man
Mid-South Tennessee
Just WOW!!! Thank you to all who contributed to this vast wealth of information. I might just print the entire post. I've been on other forum's that crashed and lost a lot of info.
Fedwrench
Valley of the sun
Jaysreal
Pittsburgh, PA, USA
Isn't Matco part of the Apex Tool Group? If so, the Gearwrench 80305 would be the cross to this Matco set. Here is a link to Amazon: https://www.amazon.com/dp/B000NICEVC/?tag=atomicindus08-20
No, Matco hasn't had any connection to Apex since Danaher/cooper owned them all. DANAHER sold Apex to Bain Capital but retained Matco, Keithley, tektronix, Fluke, etc. DANAHER did a "spin off" not too long ago so now those companies are under another publicly traded entity called Forgive. https://www.fortive.com/our-businesses/business-directory
Sent from my ASUS_I01WDX using Tapatalk
akhappy
Alaska
080-000-513WB
Magna-Tip Ratchet Handle
From Brownells is Williams WRST4/SSDMRT4 4" Shank T-Handle Ratcheting Screwdriver
Ozz316
Kansas City
Anyone make the MT2779 equivalent? I know Napa's impacts used to be sourced from the same manufacturer, didn't know if this was still true or not.
bry@n
Ocean County, NJ
Did Armstrong have anything rondo with this?
lowside67
Vancouver, BC
Snap-on/Blue Point
Wrenches:
BLPCWS711B 11pc BP Combo Wrench Set (3/8"-1") - Williams 11007
I see that the Williams 11007 is made in Taiwan and it makes sense if it is the crossover for Bluepoint.
Williams WS-1171SCA is made in USA - does anybody know if this is a direct copy of the Snap On wrenches?
Thank you,
Mark
logixjock
Sturgeon, MO
Thank you,
Mark
IDK, but that sure looks like a Flank Drive Plus on the open end.
pontoon
CA
Someone indicated GearWrench extra long ratchet flex head/non ratcheting 0 degree box 86126 is equivalent to Matco SRFBZLM102TA.
The GearWrench wrenches ARE NOT equivalent to Matco. I have both now and can confirm the two measure and perform differently due to their design. Particularly on the 14mm the GearWrench is inferior on 14mm hex fasteners. Matco overall is more straight, nicer finished, slimmer everywhere (better access) and nicer components.
Not at all hard to tell the difference. The only similarity is the type of wrench (double box XL single flex spline). Saying these are the same is like saying Craftsman and Snap on combination wrenches are the same. I hate the 14mm GW I got. I do wish Matco was cheaper (even though it is nice). Over $500 for a made in Taiwan set is insane.
Neggy
this is the 40 dollar version of a light MAC sells for almost 160 dollars, I didn't pay 160 for the MAC one, but I do own one, and one of these too.
MAC is notorious for re-boxed or brand it with our name tool offerings.
Armatron
I really like this light. One issue, at least in the ez-red version, is the battery does not seem to be "protected". And if fully discharged (light left on), the electronics will refuse to charge it.
If that happens, your options are somewhat limited. There are some tricks to force-charging these lions, I don't recommend it.
I was able to track down a replacement. It's not a standard 3.7 lion, and the connector is proprietary as well. I bought the battery below, and (CAREFULLY) spliced the OEM connector onto the new battery. The new battery is protected, and in theory should shut the battery down before the charge gets too low.
ttpete
Dearborn, MI
That's an 18650 Li-ion cell with a pigtail attached.
shakenfake
Shlumpt, TX
Is this mic still on? Matco rebrand delivery today. More on the way possibly, will edit if I get around to adding it. Interestingly enough I think all of these lights and chargers are mainly coming from the EU as I can find multiple rebrands in Europe for this stuff.
Matco PCSMRTCD - Carlyle CHT MWCP2
Matco PCSMRTCS - Carlyle CHT MWCP1
Matco PCHDLMP - Carlyle CHT WCOBHL
These are the European eBay items. I did not see this on USA eBay. They also have bundles for this stuff at the end so shipping may be worth it if you were buying a few of the items in a bundle. I just don't want to deal with shipping overseas for the most part. Plus the only light I really want is the flood light from there.
Matco PCFLOOD - eBay LED-007
Matco PCFLASH - eBay LED-008
Matco PCSMRTCD - eBay LED-A02
Matco PCSMRTCS - eBay LED-A01
Matco PCHDLMP - eBay LED-009
I just found that the brand for these items is BOXO. I guess it is a Euro brand? I am not too sure. I will link their store page here: BOXO
WWheeler
Middleofnowhere USA
Toyota oil filter tool
MAC PBT71117 / MATCO TOY117 = the OEM tool is PBT Toyota/Lexus Heavy Duty Oil Filter Tool (PBT-71117)
These Toyota filter housings will seize up no matter what you do and can really be a pain. The main go-to is a Blue-Point OFTOY468 but this PBT is a very close second IMHO. I got to see one to use in the shop today after someone had already mangled theirs pretty good at home and brought it in and seeing that convinced me to order myself one.
EDIT: And why hasn't this thread superceded the pinned one by now?
mpro323
I don’t think these have been posted before so I’ll add them. The Snap On WBSET wire brush set appears to be the made in the same Cambodian factory as the Richard 03234 available from Sutherlands. The Snap On retails for about $20 and the Richard for about $6. Granted, the Snap On set contains two brass and one stainless steel, where the Richard is one brass, one stainless steel, and one polypropylene. The US patent number listed on each is the same so I think it’s not a stretch to call the Richard an “equivalent.”
https://sutherlands.com/products/item/7815095/richard-tools-3-piece-mini-wire-brush-kit
https://shop.snapon.com/product/Wire-Brushes/3-pc-Miniature-Wire-Brush-Set/WBSET
